Old 04-29-2020, 06:24 AM   #1
2019 25' Globetrotter
mobile , Alabama
Front right lazy jack not working
Hello,
After 3 months my GT25FB Front right does not respond. ?? Anyone with advise as to where to start the trouble shooting ?
linstal99 is offline   Reply With Quote
Old 04-29-2020, 08:31 AM   #2
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by linstal99 View Post
Hello,
Hi linstal99,*
We're sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 04-30-2020, 05:08 AM   #3
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Please let us know what you find out from AS. I’m still getting used to using those powered jacks. I don’t get the blocks at exactly the same height on each set, so one jack always seems to touch first. I’ve been just holding the button down until they stop. Hoping I’m not torquing the trailer, or burning up a jack..
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 05-02-2020, 05:22 PM   #4
mobile , Alabama
Haven't heard back from Airstream yet but I'm pretty sure you want to stop the upward lift the second both jacks touch the ground. In case your wondering, a really good approach to side-to-side leveling is a set of 4-foot 2x10's. I've rarely had to use more than one but if 2 are needed I try to back a good distance to the rear of the intended parking position. That way I can PULL onto one then 2 boards. The 10 inch width will likely prevent tire damage as a result of having a tire edge hanging off the edge of a board.
If you use a X-chock( very inexpensive on Amazon) to prevent tire movement once your in position you may want to attach a brightly colored ribbon/rope so that you don't forget to remove it prior to driving off. These devices are very small and all you'll need is a moment of distraction and...
Happy Air-streaming partner
Old 05-02-2020, 08:20 PM   #5
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Hello,
Welcome to the forum but sorry to hear you are having trouble with the stabilizers.
Hope you can get it fixed without too much trouble.
Old 05-03-2020, 06:34 AM   #6
GettinAway's Avatar
Wildwood , Missouri
I use Andersen levelers and so far have been able to get it leveled side to side. I use the giant LEGO blocks under the stabilizers. Just seems like one always hits before the other. I actually prefer the old manual jacks. I wonder if you can just disconnect the motor somehow and crank them down one at a time with a cordless drill. Worked great for the last 15 years.
2020 25GT FBT
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Right blinker and brake light not working,1995 Sovereign cgseanp Lights - Interior & Exterior 18 06-01-2018 09:26 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Rear right side turn signal not working s4misfaction Argosy Motorhomes 4 05-27-2010 03:39 AM
Front Right Jack Won't Come Down swebster Mechanics Corner - Engines, Transmission & More... 8 01-17-2004 08:03 AM
