Old 05-09-2021, 04:19 PM   #1
naildriver58's Avatar
2019 27' Globetrotter
Fayston , Vermont
Fresh Water fill leaks/schematic
It appears that I have a break in the FW non-pressurized fill on my 2019 GT 27’ FBQ and I’ll need to check the connections from the outside fill to the tank. I can hook up to the City Water via hose with no leaks, however when I fill from the inlet it pours water thru the bottom “skirting” and I also get some water under the shower and into the front bedroom.
It would be very helpful if someone has a fresh water isometric drawing, I couldn’t find it in my AS manuals. Also, is there a trick to removing the cladding that appears to cover the bottom of the trailer? I may need to see the lines from underneath or drop the freshwater tank.
Any advice would be most appreciated...
Karl
naildriver58 is offline   Reply With Quote
Old 05-09-2021, 04:32 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Karl
Can you find the pump from inside the trailer? That might give you a view to the fill hose and vent. Not sure where it is. Look inside at the same area as external fill port.
Gary
GCinSC2 is offline   Reply With Quote
Old 05-09-2021, 05:36 PM   #3
Fayston , Vermont
I’m happy to say that upon further and deeper investigation in the area under the wardrobe I found that the fill line had come loose from the exterior fitting. It was a bit tough to access, but I got it put together.
Thanks for your input!
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
