Old 01-04-2021, 08:13 AM   #41
2018 25' Flying Cloud
Springfield , Illinois
Mirror image
Voyager came with our 2018 FC. Also a bit surprised with the level of technology, suction cup bracket broke early on, intermittent water infiltration problems. No biggy, still much better than nothing for towing.
More recently, on two occasions, the image flipped such that right was left and (obviously) vice versa. First time in heavy traffic; luckily I don't rely on it exclusively, or there could have been HUGE problems.
How can this even happen? I have yet to contact Voyager which I will do before the coming season.
Silverfox58 is offline   Reply With Quote
Old 01-04-2021, 09:04 AM   #42
2019 25' International
Providence , Senior Electrical Engineer
I believe there is a flip button as one of the choices on the front panel?
kittmaster is offline   Reply With Quote
Old 01-04-2021, 09:11 AM   #43
No flip switch on my model WVOM541AP. Of course I pulled the plug and reapplied power, still in the flipped position. Eventually it just returned to normal image while still powered on.
Old 01-04-2021, 09:54 PM   #44
2021 27' Globetrotter
Malibu , California
If you press the Power button for a few seconds, it offers you to flip and mirror the image.
CMHM is offline   Reply With Quote
Old 01-05-2021, 06:41 AM   #45
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
I believe that circuitry and firmware within the camera stores the selected image presentation mode settings. If there is water within the camera this could cause erratic behavior.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 01-09-2021, 09:18 AM   #46
2020 27' International
Brentwood , California
We have a 2018 F250 - purchased Builtright and RAM mounts to setup iPhone, GoPro and the review display.
https://builtrightind.com/collection...17-f-250-f-350
https://www.rammount.com/mount-builder
Order the RAM mounts on Amazon.
Photos attached
ID:	386556   Click image for larger version
2020 International Serenity 27FBT
2018 F F250 Lariat Ultimate
2017 Shelby GT 350
2015 Grand Cherokee Summit Eco Diesel
hobbie1 is offline   Reply With Quote
Old 01-10-2021, 07:12 AM   #47
BoscoMN's Avatar
Hi Hobbie1,
Thanks for the post. I just ordered one of those mounts for my F-250. Can you tell me how you removed the tray to mount the BuiltRight bracket? It looks like there are two screws under forward part of the tray near the speaker that need to be removed first and then the tray pops out?
Tom
Name:	Display mount 3.jpg
2018 F-250 6.2L Gas
Old 01-10-2021, 08:37 AM   #48
Sumterville , Florida
Two 7mm bolts forward, and three clips at the rear. The clips require a good bit of force but eventually release. Built right has a YouTube install video.
I lost one of the white clips into the depths of the dash. Ford wants $2.50 each, minimum order of four so try not to lose one.
SVTOTEM is online now   Reply With Quote
Old 01-10-2021, 08:45 AM   #49
Hobbie1, can you provide the part number for the ball attachment that mounts to the Voyager?
Thanks.
Old 01-10-2021, 10:48 PM   #50
Install just follow the Builtright instructions recommend you go to Orilleys and get a set of trim removal tools.
Amazon link from the ball https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For the arm
Ph mount
You will need some mounting screws and nuts. I went to Ace and got some black hex screws and nuts. It’s a little tricky getting them installed and easier if you mount the balls before mounting the Builtright bracket
2017 Shelby GT 350
Old 01-11-2021, 07:51 AM   #51
Thank you, but the question regarded mounting of the Voyager display. I have all the other material for the phone.
I do not have the display yet so can’t see the back of the unit. What RAM part number do you use to mount the display to the arm?
Old 01-11-2021, 01:47 PM   #52
The one above that says Amazon "ball" is it..... fits perfect.
https://www.amazon.com/gp/product/B0...asin_title_o03
_s01?ie=UTF8&psc=1
2017 Shelby GT 350
Old 01-11-2021, 01:51 PM   #53
Here is a shot of th back of the Voyager with the RAM mount
You need 2 - one for the back of the display and one to mount to the Builtright rack plus the extension arm..
2017 Shelby GT 350
Old 01-11-2021, 03:09 PM   #54
Great! Thank you, that is what I needed. It looks like you needed to open the case, but found room for the nuts and washers inside without interference with electronics. I am surprised there was easy access and room.
Old 01-11-2021, 11:04 PM   #55
No need to open the case. It's a standard mount. You will remove the factory suction mount, use the factory screws and screw on the RAM ball. Easy.....
2017 Shelby GT 350
Old 01-12-2021, 05:30 AM   #56
That is good news. Thank you for getting me up to speed.
Old 01-13-2021, 10:14 AM   #57
BoscoMN's Avatar
I have used and am impressed with Ram Mount products. The 10" iPad that I use for my current camera display is held up with them. However, they are relatively heavy and so for the Haloview camera monitor I am going to try out 67 Design's carbon fiber arms. That way the total weight hanging off of the dashboard will be less. I believe the rigidity will be the same for this application.
https://www.67d.com/collections/arms
2018 F-250 6.2L Gas
Old 01-15-2021, 04:42 PM   #58
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Got the Voyager 6” adjustable mount
BoscoMN, thanks for sharing the 67 Design link. I saw a photo on their website showing their 55 Series bar mount on a RAM truck dash above the radio. I really liked the setup but it got expensive once I added up the parts needed.
That got me thinking about using the Voyager 6” adjustable mount in the same spot of the dash. I found it on Amazon for $28.
There are two screws under the rubber cover. The base on the Voyager mount was just a little too wide. Rather than cut it down and have to install Rivnuts, I made a new plate out of 2” flat stock and used the factory screw locations with 1/2” longer trim screw.
A little paint and a new pad cut from a mouse pad and I can still fit the TST TPMS monitor next to it with Velcro. No more suction cup mount on the windshield and the ball mount is easy to loosen and remove the display when not using it.
Swap two screws and it’s back to the way it came from the factory. I always learn something from these threads!
-Jeff
ID:	387015   Click image for larger version
ID:	387017   Click image for larger version
ID:	387019   Click image for larger version
ID:	387021   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Rearview camera rp709 Electrical - Systems, Generators, Batteries & Solar 0 03-18-2012 07:16 PM
Successful installation of wireless backup / rearview camera longdog Audio, Video & TV 29 08-22-2011 01:51 PM
installation of rearview camera C A Campbell Electronics & Connectivity 3 09-08-2010 04:34 PM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 02:50 PM
Rearview Camera Sysytem moosetags Electrical - Systems, Generators, Batteries & Solar 1 08-21-2006 03:30 PM
