Old 10-31-2019, 10:34 AM   #1
Dometic Thermostat
The person who guided our walk through cautioned against programming the thermostat. Itís been very cold over night here in AZ, down in the 30ís. Iíd like to just set the furnace to come on for an hour or so prior to us rising out of bed. Should there be any problems with doing that?
Thanks!
PamK53 is offline   Reply With Quote
Old 10-31-2019, 10:51 AM   #2
2019 25' International
Providence , Senior Electrical Engineer
What was the caution and why?
kittmaster is offline   Reply With Quote
Old 10-31-2019, 11:51 AM   #3
Long Island , New York
It will help if you would please identify the year, model and length of your Airstream. You can also add this info under your User Name to the left, via the User CP link at the left end of the blue menu bar above.
If I had to guess, why you were cautioned to avoid programming, because errors may result in a "no heat" situation. In contrast, doing the heat manually at first will reduce errors, but obviously require more supervision.
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 10-31-2019, 12:01 PM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The programming is not very user friendly and only gives you two states, but I use mine all of the time to warm up the trailer before I have to get out of bed.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-31-2019, 01:58 PM   #5
Glitches AS hadnít worked out. We should have asked more questions... not sure if the issue was programming to switch between furnace and AC.
Old 10-31-2019, 02:00 PM   #6
Good luck,
Peter
My mistake... 2019 Globetrotter 27FB
Old 10-31-2019, 02:03 PM   #7
Thanks . . . happy trails!
Peter
Dometic thermostat zone 1 Tino643 Electrical - Systems, Generators, Batteries & Solar 17 10-13-2015 03:40 PM
Dometic thermostat Tino643 Electrical - Systems, Generators, Batteries & Solar 4 05-25-2013 09:42 PM
Dometic Briskair thermostat not working on heat perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-23-2012 07:07 PM
Dometic CCC 2 Thermostat (12 button style) Terratravels 2009-2015 Flying Cloud 12 10-22-2012 06:53 AM
Dometic RM100 electric thermostat problem blickcd Refrigerators 0 08-31-2009 10:32 AM
