Old 09-14-2019, 10:31 AM   #1
barnlight's Avatar
2020 25' Globetrotter
Bend , Oregon
Connecting Wally SAT Box in 2020 Globetrotter.
ID:	352144Click image for larger version
ID:	352145Click image for larger version
I am trying to hook up my Wally Dish receiver inside the 2020 Globetrotter. Other forums say the Sat Cable is inside by blue ray. I cannot find a loose sat cable. I have included pics of what I see. Any recommendations on how to do this?
Thanks, Bryan
barnlight is offline   Reply With Quote
Old 09-14-2019, 10:57 AM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Originally Posted by barnlight View Post
Attachment 352144Attachment 352145Attachment 352146
Thanks, Bryan
Yep! Start taking things apart. I see there is a speaker cabinet door nearby, open it and look for the cable. I swear they hide them sometimes! Mine was halfway down the wall next to the TV cabinet (Classic30).
You've taken the BluRay player box out I assume? Most of the time it is under there.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 09-14-2019, 05:01 PM   #3
2019 27' Globetrotter
Salem , Oregon
My 2019 Globetrotter in FB Twin. The sat cable is located in the wall behind the cabinet that houses the blue ray. Player.
Remove blue ray and you will find panel is held in with three screws you should be able to reach in and pull cable out. I can send pictures or post pictures if you like. Dave
NoResults is offline   Reply With Quote
Old 09-15-2019, 08:18 AM   #4
barnlight's Avatar
Bend , Oregon
Finally Found SAT Cable
I finally found the SAT Cable. I had to completely remove the box where the Blue Ray was and then open the side compartment where the speaker is. It was laying in there. I guess Airstream wants to make you work to hook up Satellite.
Was hoping the Wally would fit where the Blue Ray was, but the cutout is too small. I will have to make some modifications. Thanks for everyone's help.
Bryan
Old 09-15-2019, 11:41 AM   #5
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
FC27 Wally Install
Here is how I did mine. I purchased a 4input-2output HDMI box from Amazon (found on another thread) thought about ditching the DVD/bluray but found with a little wood work I could fit the HDMI box on top with velcro and then mounted my Wally and Apple TV on top. Made a strap to hold those two devices in-place and works well. The RF remotes make all the difference I just keep forgetting to turn on the HDMI box. OH and I added a 2 to 6 electrical outlet to handle the four devices. I found several different ideas here in the forums and this is my version. YMMV
ID:	352200   Click image for larger version
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky #28279
2018 FC27FBQ
2018 RAM 1500
KD3OBX 146.520
cptdzl is offline   Reply With Quote
Old 01-04-2021, 10:05 AM   #6
2020 33' Classic
Sedalia , Colorado
I have a 2020 Classic 33'. Using a Dish Playmaker and Walley. I will second that . . . Airstream did not make it easy to find. Thanks to this forum and then a call to Airstream headquarters technical support, it was confirmed that there is a Sat cable that is supposed to be under the DVD player cabinet. Mine was not . . . and Airstream told me I needed to go to a dealer to find it. Instead I went to HD and bought one of those contractor cameras. After 90 mins of looking everywhere, I found it coming out of the hole to the right of the projector behind the curtain housing. It was only five inches long and was running the opposite direction. Without the camera I would have never located it . . . I had to buy a 3ft coax cable and an F Splice connector and Bam . . . I now have Satellite. No thanks to Airstream.
Pastorius is offline   Reply With Quote
Water in Exterior Cable/Sat Connection "Box" UnklJoe Audio, Video & TV 2 12-13-2020 02:55 PM
2020 Globetrotter 23FB Twin Price FPT Dollars & Cents 1 08-27-2019 12:50 PM
2020 Globetrotter 23FB Twin - Dometic RMD 8555 wont run on battery dianacr 2018 - Current Globetrotter 29 08-04-2019 08:06 AM
Easter Egg? 2020 23í Globetrotter FBT jeffmc306 2018 - Current Globetrotter 11 05-22-2019 03:22 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
