Hopefully you can find a replacement set screw. Ours loosened up also and fell off, but the set screw was still in place. Just need the right size Allen wrench.
On the set screw - mine kept coming out and I had read about the wood glue trick. It really worked! (Just use some wood glue on the set screw - not permanent but keeps the screw from coming out).
