Originally Posted by jdink
I can get the aux speakers to work when im watching the TV in the lounge area, but when im watching the bedroom TV i cant get it to play through aux stereo speakers. audio only comes from TV speakers on bedroom tv. Is this the normal setup? Thanks
Disclaimer - I haven't done this, but have high confidence that this will work.
If you'd like the audio from your bedroom TV to play through the Polk audio system, you could use a Bluetooth optical to transmitter such as
this on your bedroom TV. You would pair it as an input to the Polk audio system just like any other Bluetooth source. BTW, external Bluetooth sources work well for me - test an external source like a cellphone to make sure yiur system will work as expected.
Alternatively, a possibly simpler solution depending on your TV source might be to take the output from somewhere else as the external input to the Polk system. For example, if you're watching a DVD or satelite TV on your bedroom TV, there is a simpler solution.
So do you want to have the TV receiver in your bedroom play everywhere, or a source that your TV is watching (e.g., DVD, satellite, streamer, etc) play over the 'house' audio?
