Old 09-01-2019, 08:08 PM   #1
2020 Globetrotter 23FBT
2020 23' Globetrotter
Sausalito , California
Another Dometic RMD 8555 question
I have another question regarding the Dometic RMD 8555 3 way refrigerator. We had some repair work done recently on our new 2020 23FBT when it would not run on 12V after purchasing in July. It worked on propane at the time. Now we are using it for the 1st time since the repair and are plugged in. The fridge is working fine but it’s very hot and we wanted to accelerate the cooling process by using propane. It alarms immediately when selecting propane. Tanks are full and the stove works. According to the manual troubleshooting section, if it doesn’t operate on gas, there should be an upstream shut off device that must be open. (No picture in the user or installation manual). We are wondering if the dealer could have shut it off when fixing the 12V and forgot to open it. Is anyone aware of a shut off device and if so, would you describe it and it’s location. In the exterior panel we see the gas connections, but a shut off valve isn’t readily apparent. Thanks!
dianacr is offline   Reply With Quote
Old 09-01-2019, 08:59 PM   #2
2018 27' Globetrotter
Mooresville , North Carolina
This is a comment I had on another post in the GT forum re: the refrigerator. Whenever I went to choose propane it would not accept that entry. The flashing red triangle button resets the system. I pressed that button and then propane started working.
"On another note, my Propane would not work on the fridge this morning so I had to use the battery. My wife found out that sometimes air gets in the lines between trips. I pressed the flashing red triangle button. That is also a reset button and now it works."
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 09-02-2019, 01:48 PM   #3
Thank you GOUSC! Problem solved. [emoji106]
Old 09-03-2019, 06:43 AM   #4
I have to give credit to my wife for that one. I had the issue when trying to use my batteries as a source and then propane wouldn’t work. She searched the Airstream Addicts Facebook page and found that solution.
"Roadrunner"
2020 Globetrotter 23FB Twin - Dometic RMD 8555 wont run on battery dianacr 2018 - Current Globetrotter 30 07-29-2022 06:20 AM
Dometic RML 8555 - mobile repair in Phoenix? BobbiHapgood General Repair Forum 2 01-05-2019 03:32 PM
Anyone successfully had a Dometic RML 8555 fixed...? HappyHapgood General Repair Forum 1 12-30-2018 03:28 PM
Just another hello from another newbie nanaenes1 Member Introductions 7 12-16-2014 11:45 AM
Another trip, another repair swanky Classic Motorhomes 6 07-07-2009 02:24 PM
