Old 06-09-2021, 07:11 PM   #1
2022 27' International
Belleville , IL
A/C not blowing cold
2020 gtfb 23. A/C with micro-Air easy start. We are at a Harvest Host brewery plugged into a 110 30 amp and the fan will run but no cold air. What should I check?
JimMussulman is offline   Reply With Quote
Old 06-09-2021, 07:18 PM   #2
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Can you tell if the compressor is running or not?
If it's not I would start by troubleshooting the easy start. http://www.micro-air.com/support-doc...leshooting.pdf
88Limited is offline   Reply With Quote
Old 06-09-2021, 07:48 PM   #3
Belleville , IL
It sounds like the compressor is running but the air coming out is cool not cold. Thermostat set at 66 and out door temp is high 80’s.
Old 06-09-2021, 08:14 PM   #4
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Unless you have tools etc about the only thing I could recommend at this point is make sure the coils on the roof are clean and your filters are clean. Otherwise it might be time to call a tech. Maybe cycle power for giggles and grins but I doubt that will do anything.
Old 06-09-2021, 10:00 PM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I'm fighting at least a similar fight myself right now. Installed the EasyStart a few months ago, and in the testing done immediately afterwards, everything performed perfectly. Now, a couple of months later, when I really need the cool air, my compressor will kick in as it should, but it only runs for about 2 minutes and stops abruptly. Yours may be doing something similar. Make sure that the compressor is actually running. All you need is a philips screwdriver and a ladder to get on your roof. If you can take the shroud off of the AC, you will be able to put a hand on the compressor and confirm that it is actually running, and you can also observe the EasyStart. If it is causing the compressor to stop running, there are diagnostic LEDs that will light up to give you a clue as to what is happening.
good luck!
Old 06-09-2021, 10:05 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Reminder: clean your intake ceiling-mounted air filters.
If you have not popped off your filter covers (2 rectangular screens mounted in the ceiling below each AC unit - for ducted systems) and cleaned your foam intake filters recently, you should start there.
You would be amazed at how quickly they get full of dust and restrict airflow / reduce cooling efficiency. Common maintenance issue. Takes < 5 minutes to correct.
wulfraat is offline   Reply With Quote
Old 06-10-2021, 09:33 AM   #7
1985 31' Excella
st. Paul , mn
1st off - a year old , or less --- take in for warranty .
Not that I would say to stay away for learning [ most do not want to bother - many of those can't ] , but these are 2 separate subjects to learn +++ buying tool needed to work on both .
Electrical theory & HVAC .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 06-10-2021, 09:56 AM   #8
2019 25' International
Washington , Washington, D.C.
Isn’t it a “no-no” to use your A/C on a 110 line? Doesn’t it greatly shorten the life of the compressor? I’ve read this in Blue Beret. The AS techs at JC have told me this. People around campfires have told me this. Does the EZ Start negate that advice?
PatLee is offline   Reply With Quote
Old 06-10-2021, 10:21 AM   #9
2008 27' Safari FB SE
Miami , Florida
The A/C is rated for 120VAC which is the US standard house voltage. It would be unusual to find 110VAC in 2021 but could happen. The A/C would probably still run but would draw more currrent.
Middle-aged (usually dirty) Nissan Titan XD
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Goofy dog
Old 06-10-2021, 12:00 PM   #10
Coast to Coast
Two Peas's Avatar
2016 26' Flying Cloud
Winston Salem , North Carolina
After 5 years we lost our Dometic AC. Blowing but not cold. Talked with JC. Either a control board or compressor. The first of which is the only thing you can replace without replacing whole unit because it is "sealed". Cha Ching. $2k total but shipped overnight and with install.
Two Peas is offline   Reply With Quote
Old 06-10-2021, 12:55 PM   #11
2014 30' International
DFW Airport , Texas
Where are you plugged in? Camp grounds infrastructure has so deteriorated that its possible you are not getting 120V during the start phase because of all the other ACs running upstream from yours.
I would definitely power down the whole trailer, disconnect for 5 minutes, cycle the breaker 2 or 3 times to disturb the corrosion, plug in, power on and switch only the AC on, all other breakers off. See what happens.
Vlamgat is offline   Reply With Quote
Old 06-10-2021, 01:46 PM   #12
1988 32' Excella
Robbinsville , New Jersey
This is 120v 30 amp the most the OPs trailer was designed to use. What your not supposed to use the A/C on is 15 amp 120v.
Old 06-10-2021, 01:50 PM   #13
1988 32' Excella
I believe that it is really 120VAC. Unfortunately millions of people insist on saying the antiquated 110 volt which hasn't been the standard for many decades.
Old 06-10-2021, 03:15 PM   #14
amxpress's Avatar
Clayton , North Carolina
I had a similar condition with my 2021 Dometic. Blows warm or a little cold. Compressor cycles too quickly. Dealer
found a foam strip that separates the air intake with the air output chamber was too short allowing the air to blend inside. He installed a longer piece of foam which separated the chambers which corrected the condition.
amxpress is offline   Reply With Quote
Dometic Air Conditioner Not Blowing Cold Wconley Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-25-2018 09:05 AM
Suburban Heater Blowing Cold Air occasionally Cody Madison Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-20-2014 03:39 PM
Oh oh, heat pump only blowing cold air almcate Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-17-2013 03:17 PM
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-26-2013 11:14 PM
A/C not blowing cold anymore hollandranch Furnaces, Heaters, Fireplaces & Air Conditioning 17 09-26-2007 10:44 AM
