Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 09-09-2020, 07:41 PM   #1
2019 27' Globetrotter
Larkspur , Colorado
12vdc schematic for 2019 GT
Iím looking for the 12vdc schematic for a 2019 GT. Might be overkill but my outside entry light is suddenly not working. Fuses all look good. Being an LED, Iím really doubting a bulb failure but want to try to trace it. The schematic in the manual only covers the major items and even the fuse block only has descriptions for the first 8 (of 13) fuses. Hoping one of you might have it. Thanks!
Dmmdtm is offline   Reply With Quote
Old 09-09-2020, 09:14 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Its located on the inside of the DC distribution cover. Good luck being able to see it. Best get a magnifying glass. Best bet is to check the area behind the switch. Wire loose would be my best guess
Old 09-10-2020, 07:38 AM   #3
dst
The Woodlands , Texas
Part of our light occasionally goes out. I tap on the housing and it comes back on. Cheap led strip, and mounted crooked in the housing just because there was no quality checklist entry to check that.
The fact it is over the door is annoying: you open the door to the swarm of bugs gathered around the light. I miss the larger side light from our flying cloud and the small light at the steps.
dst is offline   Reply With Quote
Old 09-10-2020, 07:45 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have a post on this somewhere. The problem is usually a bad ground for the fixture. In my case, there is a rivet holding the lamp fixture to the casing, which is the ground. The rivet was never squeezed hard enough to form a tight contact. Once I crushed the rivet with a c-clamp, the light has been functional ever since.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-10-2020, 06:58 PM   #5
Larkspur , Colorado
I think you’re on the money. In the dark I noticed that 2 of the 8 LEDs seem to be working. Raining now, but I’ll try some strategic tapping tomorrow.
12v
Dometic refrigerator 12vDC operation walter1 Refrigerators 19 08-29-2013 12:47 AM
Thinlite 12Vdc Flourescent lights Calvin Electrical - Systems, Generators, Batteries & Solar 3 04-19-2007 02:12 PM
12vDC wall connectors walter1 Electrical - Systems, Generators, Batteries & Solar 10 09-19-2004 01:53 PM
Refrigerator 12vDC walter1 Refrigerators 2 09-16-2004 11:53 PM
Interior 12vDC bulbs walter1 Electrical - Systems, Generators, Batteries & Solar 6 09-13-2004 03:23 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
