I don't believe there is a difference between the 2017 and 2018 front room table setup in the U models as regards cushions, pedestals, and table top sections. The 'option' is to convert the area into a full size bed for up to double occupancy or, to leave a single table piece in place (spun) and use the two side berths as separated singles once the curved end cushions are removed (typical use when kids travel).
If your spouse hated the prior cushions you can expect the same reaction to the new unit if equipped as "factory built" as opposed to custom replaced cushions using a different foam density.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
