I found some grommets with a neck to fit the whole...top and bottom of pump bracket. No need to crank it down like AS does with a drill driver. On the contrary, firm enough to keep it in place...lose enough to let the rubber grommets do their dampening thing. I also put a sheet of old ensolite pad below the pump to line the floor, probably overkill as the pump isolation the pump, and warring the lines & connections (see earlier post) was the key to the pumphouse noise.....noise still elsewhere.
2019 23' Flying Cloud
West Sacramento
Just purchased a new 23 fb and filled the portable water tank. I bleed the lines and it still makes a racket. Dang.
I have sound insulation but being brand new as in a week old I shouldn't have to do this.
Check the screws holding down your water pump. On my new 28 Serenity only two of the four screws were screwed down. The other two screws were there, but not screwed down.
brick
brick
2018 International Serenity
Cute wife...
