Old 06-15-2021, 11:04 AM   #1
2017 25' Flying Cloud
Indianapolis , Indiana
Water pressure gauge?
Does anyone here use a water pressure gauge when hooking up to city water? If so what do you set it at?
Muntjac is offline   Reply With Quote
Old 06-15-2021, 12:05 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
A water pressure gauge is a device that reads out the water pressure.
A water pressure regulator is a device that limits the water pressure.
I'm guessing you are asking about a regulator rather than a gauge.
Most / many modern AS trailers already have a pressure regulator built into the city water inlet. There is no need to use an external device.
Old 06-15-2021, 01:16 PM   #3
Mollysdad's Avatar
Hi
Best of both worlds.
I use this.
https://www.amazon.com/Renator-M11-0...3784347&sr=8-5
That 'brand' got the best reviews.
My city water hose has become a science project in that I use a "Y" on the supply line so I have some grip, then quick release fittings almost everywhere to make connections leak free.
Old 06-15-2021, 01:22 PM   #4
2011 25' FB Flying Cloud
Forest , Virginia
I just checked my 2011 Flying Cloud manual and the plumbing section (City Water Hook-Up section) specifically states, “Your plumbing system has a built in pressure regulator to protect your lines and faucets…”
NDRaised is offline   Reply With Quote
Old 06-15-2021, 01:47 PM   #5
1986 31' Sovereign
Miami , Florida
If too high water pressure is a concern, a simple solution is to simply fill your onboard water tank (repeat as necessary) and use your water pump.
Your shower will be the same every time.
The water in your fresh water tank will be renewed with fresh.
If by some horrible accident a line should let loose or a faucet is left running, the pump switching on will waken you or, if you are away, the deluge will abate after 30 some gallons rather than run indefinitely.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 06-15-2021, 02:38 PM   #6
1955 26' Cruiser/Overlander
harrisburg , Missouri
a water pressure regulator and gauge will protect your hose and airstream. About 45 or 50 psi would be plenty.
Aaron
a duncan is offline   Reply With Quote
Old 06-15-2021, 03:34 PM   #7
Hi
Right - I meant regulator. Thanks!
Old 06-15-2021, 03:35 PM   #8
I use this.
Great tips. Thank you!!
Old 06-15-2021, 03:37 PM   #9
Half a Rivet Short
Hi
All regulators have a pressure drop across them. It's just how they work. If you put two in series, you get lower pressure at a give flow rate than you would with one. Low water pressure at campgrounds is (from what I've seen) more common than high pressure. Don't over do this .....
Old 06-15-2021, 03:43 PM   #10
ITSNO60's Avatar
Tucson , AZ
I use this.
I bought the Valterra version but it looks identical to yours except for the name, they probably came from the same factory. I noticed a lot of the bad reviews seemed to be the result of rough handling, I kept the original plastic package, cut it down with scissors then drilled a hole to slip a bread tie thru to secure it and that keeps it pretty well protected when travelling.
Brian
ITSNO60 is offline   Reply With Quote
Old 06-19-2021, 02:04 PM   #11
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
San Antonio , Arkansas
File this tidbit away…..
I was staying a an RV park this past winter in NC and their water psi at the hose bib was 90 measured with a water pressure gauge. That 90 psi ruined my heated water hose between the hose bib and my water filters. Camping World replaced my hose under warranty. Reading the document in the box of my new heated water hose, it clearly states 60 psi maximum. I installed a pressure regulator at the hose bib and my new hose survived the rest of the NC winter.
twbucksr is offline   Reply With Quote
Old 06-19-2021, 03:53 PM   #12
2019 27' International
Western NC , North Carolina
We were recently at a campground that knows that have high pressure at the bib, they were selling pressure regulators when you check in, reason being the high pressure blew up hoses and filters before the trailer.
We just used our adjustable one like shown above.
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Tire Pressure Gauge SGT DAVE Sprinter and B-van Forum 17 01-08-2013 11:07 PM
Air pressure dash gauge raveson Classic Motorhomes 1 03-11-2008 09:59 PM
Oil Pressure Gauge alexzero13 Mechanics Corner - Engines, Transmission & More... 3 07-25-2007 08:36 AM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
