Old 04-15-2021, 05:41 PM   #1
2017 30' Flying Cloud
VICTORVILLE , California
Water leak floor replacement?
Hello Airstream family,
We have a 30 ft bunk, we started seeing some discoloration on our bathroom floor in the summer time but thought we had a leak in the shower so we caulked the seams. We then started seeing the discoloration in the galley area so we started looking for water leaks outside and noticed a drip coming from the gray and black valve handles, we then followed it to the city water inlet. We pulled it out and found that the valve wasn’t tightened enough, we pulled out the drawers in the kitchen and saw the insulation was completely soaked thru. We have put a fan in there and a damp rid bottle to help dry it out. I did call our insurance company and they are calling it a manufacturer defect I know our warranty has just expired in February. The question is do you think Airstream will honor the warranty?
And if they won’t anyone have recommendations for a shop to do the repair.
Any ideas would be great.
Carbmen is offline   Reply With Quote
Old 04-15-2021, 07:45 PM   #2
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
I believe airstream will honor the warranty, which means that since this comes after the warranty, they will not cover the repair under that warranty. I could be wrong, however.
Depending on how long the leak has been going on, and more specifically, how long the plywood has been wet, You may not have to replace that section of the subfloor unless the plywood has gone soft or started to rot away.
There is no cheap or easy way to replace the subfloor short of first removing everything inside the trailer that is above that section of the floor. Because this type of repair is so labor-intensive and expensive, I am not surprised that your insurance company does not want to pay for it, nor will airstream if they don’t have to. From what I gather on the forum, the way airstream regards the Warranty is that you have been “given” two (now three) full years to find any of the many factory defects these new trailers are known to be riddled with, after that time, you are on your own.
The factory will, on your dime, be happy to replace the floor for you if you like. It will be a little comfort for you to know that starting with the late 2020 models, airstream finally switched to a waterproof composite floor in all of their trailers.
If they don’t want to pay for the repair themselves, perhaps you can plead with them to cut you a deal on the repair, if it is needed.
Another option to crunch the numbers with is to consider selling your trailer now as is, and buying a new one with a new composite subfloor, and see what that would be compared to paying for the repairs to this trailer now
It would be great if you could buy insurance that would cover manufactures defect‘s after it runs out of warranty. In the case of airstream trailers, the insurance would be so expensive, no one would buy it. That or the insurance company would soon go bankrupt. It may be telling that since many manufacturers will try to upsell a new customer on an extended warranty policy, thereby increasing their profits, Airstream does not offer such an extended warranty.
skyguyscott is offline   Reply With Quote
Rotten floor due to water leak! TennisMan 2007 Safari SE 549 07-04-2017 10:23 AM
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water Leak, Floor Repair Cstar Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-05-2005 04:58 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
