Old 03-12-2020, 09:42 PM   #1
Louisville , Kentucky
Water heater
In process or dewinterizing..... new owners of 2017 27ft FB. My question: before we run the water through the pipes to clear winterizing fluids..... is there a need to shut off water access to the water heater? I know it is not flushed with antifreeze, only drained and the plug left out for winter. We have flushed it and have plug cleaned and ready to put back. But it occurred to us that we maybe are not supposed to flush the ‘pink’ through it. How do we keep from doing so? We don’t know of any bypass valve for the water heater.
Phambemiss is offline   Reply With Quote
Old 03-12-2020, 09:59 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
It has to have a bypass if your system is pumped full of antifreeze, but your WH is empty.
I wouldn't worry about pushing some antifreeze into the WH when flushing lines. I always flush them well, plus sanitize the fresh water tank and run the sanitized water through the lines before I use the water system for the season
CRH is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
