Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 04-06-2017, 02:17 PM   #1
2016 19' Flying Cloud
Portland , Oregon
Upgraded table in 19' Flying Cloud
We've been slowly customizing our 2016 19' Flying cloud. We purchased it used so didn't have the luxury to specify the interior so I've been customizing it more to our taste.
First the look of the old table with our son eating breakfast
It's just a little bland for our taste.
We purchased a butcher block table top from Ikea, $80. It's real wood, comes with a curve in the end but unfinished. All I had to do was cut it down to size, one straight line cut, sand a little, stain, seal and mount hardware from original table.
We made it 2" longer than original to account for the larger curved end.
I think it turned out well.
We are going to extend the kitchen counter a little so having the larger curved edge will be critical in enabling easy in and out of the dinette. Table top is about 1" wider.
While the table top is 1/2" thicker the bed seems to still work just fine.
Fun project. Enjoy.
Snowy is offline   Reply With Quote
Old 04-07-2017, 10:42 PM   #2
MQF
MobileQuarantineFacility
Charles Town , West Virginia
That looks great.
MQF - Mobile Quarantine Facility (2017 Flying Cloud 26U Queen) Ordered 3/10/17, took delivery 5/16/17
MQF is offline   Reply With Quote
Old 04-07-2017, 10:44 PM   #3
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Cool!
Troutboy
Troutboy is offline   Reply With Quote
Old 04-08-2017, 06:14 PM   #4
Portland , Oregon
A couple of other small modifications, cosmetic. Aluminum trim for the counter tops.
We are going to replace the counter tops at some point, this was just a way to like them more until I do that.
Here is the link to the trim pieces on Amazon.
M-D Building Products 70409 Edging A811 96-Inch Aluminum Moulding, Anodized https://www.amazon.com/dp/B000VZORBW..._SXx6ybFGWFD96
3/4" on the stock counter tops is a little short, mostly unnoticeable. I couldn't find any which was a hair longer.
Oh, then we changed out the faucets. We like these way better. These are also Ikea faucets, $80 each. Cheap change imo.
Old 04-08-2017, 06:46 PM   #5
Troutboy's Avatar
Parker , Colorado
Pretty cool upgrades. How did you bend the trim around the corners?
Troutboy
Old 04-08-2017, 07:04 PM   #6
Portland , Oregon
Amazingly the trim is pliable enough to hand bend around the corners. I just held it in place on one side of the corner and slowly bent it.
The kitchen counter top corner is really sharp and you can just see in the pic that the edging bent up a little. Apparently if I heated the trim up I could have avoided that but at the same I couldn't have bent it in place either.
On the counter below the TV I also backed the trim with some double sided gorilla tape. Worked great to stick it down hard and made the screws cosmetic really. Make sure you get it right first time if you use the tape, I screwed up on the bathroom bit and I had to destroy the trim to pull it off.
Old 04-10-2017, 11:38 AM   #7
2008 20' Safari
Somewhere , Montana
Smile
Love it!
mtcampers is offline   Reply With Quote
Old 04-10-2017, 12:45 PM   #8
2006 19' Safari SE
Courtland , California
That is so cool. Me, being a big guy - I have a tight squeeze when I sit on the stove side of the dinnette. I like a generous entery space your design provides!
dandraws is offline   Reply With Quote
Old 04-10-2017, 01:22 PM   #9
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Very nice, an idea I'll keep in mind. Also looks like it made it easier to get in and out of the seats......
banderabob is offline   Reply With Quote
Old 04-10-2017, 02:08 PM   #10
Portland , Oregon
Yes, way easier to get in and out now!
Old 04-10-2017, 04:41 PM   #11
Livingston , Texas
The table you made just makes that area look so much warmer and richer. Nicely done and the curve is practical and beautiful. Your metal trim is also a good option for any laminate trim edges (installed by factory) that have separated (gluing them back on is futile). Nice upgrades.
Seemore2006 is offline   Reply With Quote
Old 04-10-2017, 09:22 PM   #12
Portland , Oregon
Thanks! My better half came up with the ideas. "All" had to do was source the parts, cut, sand, build the table, painstakingly stain and seal it, install it then finally cut, bend and install the trim.
Anyone doing the trim, I suggest the 13/16th not the 3/4 I used. The 3/4 is exactly the same size as the material which means it peaks through at the bottom by a tiny bit. I think 13/16th would be perfect. The 13/16th will have a slight under-hang.
Here is the 13/16th link to M-D Building Products 70425 Edging A813 96-Inch Aluminum Moulding, Anodized https://www.amazon.com/dp/B000CSIJEE..._YGe7yb0YE5EFQ
I pulled off the laminate trim on one edge and was surprised how easy it came off. This covers/replaces it completely.
As for the table, I questioned my wife's choice of stain, it's called Carbon Gray, made by Varathane. I must admit it works very well with the aluminum interior, great blend of color. It's finished with 5 coats of satin Varathane Polyurethane finish so should wear well.
I might trim the table too in the future but the wife doesn't want any visible joins in the material. I'll ether need a very long strip of trim or play with a aluminum solder to join two strips. Fun
Old 04-11-2017, 07:26 AM   #13
2017 25' International
Ladysmith , Wisconsin
What is the name of the piece you bought at Ikea? I love this but cannot seem to find it on their website? Thanks!
llanderson64 is offline   Reply With Quote
Old 04-11-2017, 07:52 AM   #14
Portland , Oregon
It's called the GERTON
http://m.ikea.com/us/en/catalog/products/art/90106771/
Old 04-11-2017, 08:35 AM   #15
gecko's Avatar
2009 28' International
Pacific Palisades , California
Pretty!
gecko is offline   Reply With Quote
Old 04-11-2017, 01:14 PM   #16
Adventure.AS's Avatar
Niagara-on-the-Lake , ON Canada
Originally Posted by Snowy View Post
...Aluminum trim for the counter tops.
How did you get it to curve so neatly around the corner?
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-11-2017, 02:11 PM   #17
Portland , Oregon
Post #6
Maybe I'm just skilled
Old 04-11-2017, 11:02 PM   #18
i2oadRunnei2's Avatar
2016 23' Flying Cloud
Hillsborito , Oregon
Love the upgrades! Thanks for the parts list!
i2oadRunnei2 is offline   Reply With Quote
Old 04-14-2017, 03:25 PM   #19
2015 25' FB Flying Cloud
Sandy , Utah
Nice work! I have been trying to find a way to take care of the sharp edges on the counter tops. thanks for the ideas!
rocco52 is offline   Reply With Quote
Old 04-14-2017, 07:17 PM   #20
Portland , Oregon
Our pleasure. Even when we change out our counter tops in the future we are going to redo the edge trim like this. We love the look.
Dinette Table (table top and 2 legs) helluva Airstream Classifieds 0 04-25-2016 12:49 PM
1985 Excella credenza, fold out table, little shelf that goes on top of the credenza, table next to the front door, chairs janeinthemtns Airstream Classifieds 0 10-12-2014 10:37 AM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Upgraded from 19' Bambi to 25' Flying Cloud FB High Cloud Member Introductions 2 05-28-2013 05:29 AM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
