Old 02-01-2018, 07:46 AM   #1
Safetyfirst's Avatar
2019 30' Classic
2015 25' Flying Cloud
Safety Harbor , Florida
Tripping Breaker. Fridge or Converter?
New 2018 Flying Cloud. when plugged into shore power and running Fridge on electric, there is eventually a fan running hard behind panel under fridge and the breaker trips. So interior lights go off, fridge displays some kind of error code instead of temp and batteries begin to discharge.
Anybody familiar with that? If so, what would the diagnostic process be.
Thanks.
Ed
Safetyfirst is offline   Reply With Quote
Old 02-01-2018, 08:01 AM   #2
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Safetyfirst,
We're sorry to learn about the issue you described in your 2018 28' Flying Cloud. Please call our customer service and technical support team at*1 (877) 596-6111, option 2 so we can learn more and help.
Thanks.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 02-01-2018, 08:03 AM   #3
Baby Zeppelin's Avatar
Suwanee , Georgia
I had something similar happen on our first camping trip. Don't know if it's related to your experience.
Twenty three degree outside temp, wake up in the middle of the night with furnace not running, 48°F in the trailer. Took awhile to figure out problem after first checking breakers at power pole and at converter - problem was that the solenoid or relay that goes "thunk" when you put the trailer in store mode had self actuated. All electrics were disconnected.
Turning it back to "run" got everything going - for about an hour. Then it happened again. Happened a total of four times that morning. The last couple of times we were eating breakfast, the lights over the dinette and over the kitchen counter both flickered, then "thunk", and all power went out.
The trailer is at the dealer now having that, and a few other problems, attended to. Service Manager said in 2018 that solenoid was wired to turn off converter as well as disconnect batteries when in "store" mode. He said prior to 2018 it was not that way, and they were going to rewire the system to pre-2018 specs. Hopefully that will correct the problem.
Baby Zeppelin is offline   Reply With Quote
Old 02-01-2018, 08:21 AM   #4
2019 30' Classic
Thanks Erik. I can definitely see that being a problem. Mine is a breaker though. of course, once the the breaker is ok i may run into your issue! Hope not! Nice that Airstream was my first reply! Hopefully they’ll have some good guidance!
Old 02-01-2018, 08:50 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Your interior lights should not have been effected right away after the breaker tripped. They are 12 volt lights and should run off the batteries if the batteries are any good.
When did you get the trailer and any idea how long it sat on the lot before you picked it up? If it sat for any time the batteries are most likely bad as the would be drawn down by the CO2 detector.
I Airstream is still following this tread they should take note and not connect that detector at the factory. That should be a dealer prep function.
2004 Excursion 4x4
Old 02-01-2018, 09:27 PM   #6
2019 30' Classic
I’ve never been in the trailer when the breaker tripped but have noticed the batteries discharge very quickly.
Old 02-01-2018, 09:42 PM   #7
New Borockton , Alabama
Images: 21
Thanks.
Ed
If your lights quit, that is the converter. Airstream changed to the WFCO converter for cost. We get more calls on those than any other. You have options but best might be warranty if you don't want to upgrade to a better product yet since that would be out of pocket.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Tripping breaker Siamese66 Electrical - Systems, Generators, Batteries & Solar 9 08-20-2006 10:37 AM
a/c tripping breaker? rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 13 08-01-2006 02:59 PM
15K BTU Dometic A/C tripping breaker silverback Furnaces, Heaters, Fireplaces & Air Conditioning 48 07-11-2006 09:14 AM
AC breaker keeps tripping bmimken Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-11-2006 08:57 AM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
