Old 04-16-2018, 07:13 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
Torflex Lift on 19’ - No Can Do
I had planned to put a lift on my new 19’er only to find out it is VERY expensive to do. The issue is a propane gas line that interferes - as well as an issue with the shocks. To make the accommodations it would cost over $600 - if not more. Too much to pay for 3 inches of extra clearance. I now have one set (not a tandem) Torflex #11 axle lift to sell if anyone is interested.
tjwoods1 is offline   Reply With Quote
Old 04-16-2018, 07:23 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Contact Troutboy on the forum he did it on his 23D and was able to work around the propane line. There should be no problem with the Shocks.
Old 04-16-2018, 09:08 PM   #3
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I installed the lift kit on our 19' Bambi, and did not run into any issues involving the shock absorber.
I did have to disconnect the gas line so it would not pinch during the installation, but it was not complicated to re-install.
it was a lot of work mostly due to not having an impact wrench. otherwise it is pretty straightforward.
I did have to replace our single step with a double step.
this is a great upgrade, in my opinion.
Steamy1 is offline   Reply With Quote
Old 04-21-2018, 10:31 AM   #4
Eugene , Oregon
Took my rig to a different RV mechanic. (One that I truly trust). He did a thorough inspection, and working around the propane lines, concluded he could do it. He was going to reinforce a part where he thought the metal was a bit thin for the added sideways torque - just as an added safety concern. Looks like I’m in business.
K71-724-02: Frame Spacer Kit Fits Dexter Torflex #11 axle cinchark Airstream Classifieds 1 04-13-2018 09:39 AM
Should i lift the shell or not lift the shell.. prettybrent Repairing/Replacing Floor &/or Frame 19 09-04-2016 10:13 AM
Torflex axle on 60 Tradewind, Help w/specs streaming24 Axles 2 06-15-2016 12:04 PM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
