Old 09-27-2021, 07:14 PM   #1
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Surge Guard BlueTooth Remote
This weekend watching my Honda 2000 " SCREAM " for mercy after struggling to test run one Dometic 13.5 within our storage unit. Yes with a Micro Air it started the unit and ran it for awhile then kicked off several times.
So no big deal that test failed in Florida heat and humidity. However the surge guard remote inside the trailer logged 4 history codes of low voltage on line 1. And yes I had a floating ground plug inserted in the gen, Trailer cord was into the Honda 30 amp socket which really only can deliver 13.5-15 amps.
My question has anyone tried to clear out the Surge Guard remote Bluetooth stored history codes. I have removed the batteries and re synchronized it to the Surge Guard outside. It clears codes and then on shore power it repeats line 1 voltage low. The Surge Guard shows not faults and is working fine.
We are on a 30 amp service hooked to a 50 amp 2021 Smart Plug with a 30-50 dog bone. Never had any codes until I messed with the Honda Gen test. Or maybe I have a problem at the storage plug?
Techno RV says it will store the last 4 no one answers at Surge Guard anymore. I'm used to Automotive, fixing a code problem and then clearing them out.
Life is a Highway is offline   Reply With Quote
Old 09-27-2021, 08:02 PM   #2
2015 28' Flying Cloud
Newtown , Pennsylvania
looks to me like you don't have enough power at the storage yard. Is everything OK until you turn on the AC?
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 09-27-2021, 10:34 PM   #3
Lady Lake , Florida
Could be
That could be. Iíll try another reset when itís 124 volts however I still think the Honda trigged it.
Power watchdog surge protector with bluetooth hhendrix Electrical - Systems, Generators, Batteries & Solar 4 06-13-2019 10:45 AM
Surge Guard Hookup Aquabud Batteries, Univolts, Converters & Inverters 2 07-28-2011 10:32 AM
Where on airstream would you install an on board surge guard? bonginator Electrical - Systems, Generators, Batteries & Solar 14 08-20-2010 01:16 AM
Anyone use a Surge Guard? craftsman Batteries, Univolts, Converters & Inverters 20 11-13-2009 01:57 PM
Surge Guard; is one better than another BoJo Electrical - Systems, Generators, Batteries & Solar 3 03-08-2009 05:47 PM
