Originally Posted by GMFL
I believe the way Airstream has it wired solar will not charge in store mode.
Now with that said it can be fixed to charge in store mode. You will need to swap the (+) lead from the solar charge controller to connect to the battery side if the use/store solenoid. This can be determined by using a multi meter to find out which side of the solenoid has voltage when in the store mode.
I have a 2017 FC with factory solar and it charges in store mode (if by "store mode" you mean the switch by the front door that turns off all the power). It's nice as it is like a trickle charger over the winter.
