Old 06-30-2022, 11:11 AM   #1
hikingcamera's Avatar
2022 23' Flying Cloud
Seattle , Washington
Routing Cables from Overhead storage down to DC box
Hi,
So I am curious if folks here have had success routing cabling from the overhead storage area above their DC bus bars down to the bus bars. In our 2022 Flying Cloud 23 CBB, we have over dinette storage in the front where our WeBoost is installed that currently only has AC power up there, and I'd like to power the WeBoost and our hotspot via DC. The DC bus bar is down to the lower left (picture attached, yes, I still need to neaten up the cable mess up there, we're still mid-project).
In the end I'll go with what's easier (bringing a DC WeBoost power cord down to the DC bus bar area or bringing a 12-volt port up to the cabinet, the latter is probably preferred because then the Hotspot, interior antenna, and everything can just live up in that cabinet). I think it will cost a few hundred dollars to ask my dealer to do it, so my hope is to give it a go myself first.
Name:	Front Dinette Routing.jpg
hikingcamera is offline   Reply With Quote
Old 06-30-2022, 11:20 AM   #2
2015 23' FB Flying Cloud
Omaha , Nebraska
There should be 12 volt for the stereo in the white box to tap into.
dolson is offline   Reply With Quote
Old 06-30-2022, 11:25 AM   #3
Oh you're right. I mean, I don't think it's not in the white "multimedia" box inside the storage, unless I could tap off the USB-port that runs from the stereo. But there should be some 12-volt power inside the compartment to the right of that storage. I just need to figure out how to get into it.
Old 06-30-2022, 01:17 PM   #4
2021 22' Caravel
Houston , Texas
I believe the radio is DC powered. I guess you could tap off that?
FredWilma is offline   Reply With Quote
Old 07-01-2022, 09:55 AM   #5
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
In mine there is 110V inverter outlet up there that I use with the cell signal booster when not plugged into shore power. Did they remove that outlet?
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 07-01-2022, 10:54 AM   #6
The AC is what itís plugged into now. I want to wire into DC.
Old 07-01-2022, 01:03 PM   #7
1988 32' Excella
Robbinsville , New Jersey
Your inverter probably uses as much power as your cell signal booster (maybe more), doubling the amount of power you are drawing from your batteries.
Old 07-01-2022, 02:40 PM   #8
2015 30' International
Escondido , CA
Yes you can tie into the DC power for your cell booster
Hi,
Yes you can tie into the DC power for your cell booster, I'm doing that in my 2015 30RB, by tying into the power provided to the cabinet. See pics attached.
Name:	Tech Cabinet.jpg
dsatwork is offline   Reply With Quote
Old 07-01-2022, 03:05 PM   #9
Nice! How did yo get into the space where the DC power for the radio is> I canít figure that part out yet, lol.
Old 07-01-2022, 05:33 PM   #10
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , TEXAS
The AC is what it’s plugged into now. I want to wire into DC.
If I remember correctly, there is an extra 12v power supply reserved for the satellite receiver. Is it nearby? It's behind my radio.
JEWare
John Ware is offline   Reply With Quote
Old 07-01-2022, 08:18 PM   #11
HmmÖ Iíll have to look again. I saw the satellite cable, but I didnít notice a power supply cable. Iíll pull that cabinet open again and check. Thanks!
Old 07-01-2022, 10:45 PM   #12
Escondido , CA
DC power source in tech cabinet
If you pull out the DVD, you should see the power source. Large 10 gauge blue wires that go to the power outlet. You might have to remove the cabinet, can't remember if is was needed because my install required removing the cabinet and wall to get access for running antenna wires in from the roof.
Old 07-02-2022, 02:48 AM   #13
I may need to grab a close up picture of that area, but in mine there is only one inverter power outlet and it does not run behind the DVD plays, itís on the wall of the cabinet, not in the little multimedia box they have. There are some cables running from a hole in the wall into the multimedia box where the DVD player is, but they are all black cables. One is the satellite coaxial connection.
Old 07-03-2022, 03:17 PM   #14
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
You can also remove speaker to get to wires behind the radio.
pcskier is offline   Reply With Quote
Old 07-03-2022, 04:56 PM   #15
Oh, good tip! That might be simpler. Thanks!
Old 07-03-2022, 05:03 PM   #16
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
There are several 12volt circuits in the “entertainment center”.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Dept of ďOverkillĒ
Old 07-03-2022, 06:27 PM   #17
Originally Posted by GMFL View Post
There are several 12volt circuits in the ďentertainment centerĒ.
Yeah, I was realizing there also must be 12-volt up there for the under cabinet lighting there.
Pulling larger cables into batt box openroad118 Electrical - Systems, Generators, Batteries & Solar 0 01-06-2017 07:50 AM
Routing Battery Cables from Curbside to Street side? explore more Electrical - Systems, Generators, Batteries & Solar 9 05-24-2016 08:28 AM
What are all those cables in my battery box? RubyDog Electrical - Systems, Generators, Batteries & Solar 13 03-01-2015 08:53 AM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
