06-30-2022, 11:11 AM
2022 23' Flying Cloud
Seattle
Routing Cables from Overhead storage down to DC box
Hi,
So I am curious if folks here have had success routing cabling from the overhead storage area above their DC bus bars down to the bus bars. In our 2022 Flying Cloud 23 CBB, we have over dinette storage in the front where our WeBoost is installed that currently only has AC power up there, and I'd like to power the WeBoost and our hotspot via DC. The DC bus bar is down to the lower left (picture attached, yes, I still need to neaten up the cable mess up there, we're still mid-project).
In the end I'll go with what's easier (bringing a DC WeBoost power cord down to the DC bus bar area or bringing a 12-volt port up to the cabinet, the latter is probably preferred because then the Hotspot, interior antenna, and everything can just live up in that cabinet). I think it will cost a few hundred dollars to ask my dealer to do it, so my hope is to give it a go myself first.
06-30-2022, 11:20 AM
2015 23' FB Flying Cloud
Omaha
, Nebraska
There should be 12 volt for the stereo in the white box to tap into.
06-30-2022, 11:25 AM
Seattle
Oh you're right. I mean, I don't think it's not in the white "multimedia" box inside the storage, unless I could tap off the USB-port that runs from the stereo. But there should be some 12-volt power inside the compartment to the right of that storage. I just need to figure out how to get into it.
06-30-2022, 01:17 PM
2024 30' Globetrotter
Houston
I believe the radio is DC powered. I guess you could tap off that?
07-01-2022, 09:55 AM
2016 28' International
Trois-Rivieres
, Quebec
In mine there is 110V inverter outlet up there that I use with the cell signal booster when not plugged into shore power. Did they remove that outlet?
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
07-01-2022, 10:54 AM
Seattle
The AC is what it’s plugged into now. I want to wire into DC.
07-01-2022, 01:03 PM
1988 32' Excella
Robbinsville
, New Jersey
Your inverter probably uses as much power as your cell signal booster (maybe more), doubling the amount of power you are drawing from your batteries.
07-01-2022, 02:40 PM
2015 30' International
Escondido
, CA
Yes you can tie into the DC power for your cell booster
Hi,
Yes you can tie into the DC power for your cell booster, I'm doing that in my 2015 30RB, by tying into the power provided to the cabinet. See pics attached.
07-01-2022, 03:05 PM
Seattle
Nice! How did yo get into the space where the DC power for the radio is> I can’t figure that part out yet, lol.
07-01-2022, 05:33 PM
Escape Pod II
2018 22' Sport
Orange
If I remember correctly, there is an extra 12v power supply reserved for the satellite receiver. Is it nearby? It's behind my radio.
JEWare
07-01-2022, 08:18 PM
Seattle
Hmm… I’ll have to look again. I saw the satellite cable, but I didn’t notice a power supply cable. I’ll pull that cabinet open again and check. Thanks!
07-01-2022, 10:45 PM
Escondido
, CA
DC power source in tech cabinet
If you pull out the DVD, you should see the power source. Large 10 gauge blue wires that go to the power outlet. You might have to remove the cabinet, can't remember if is was needed because my install required removing the cabinet and wall to get access for running antenna wires in from the roof.
07-02-2022, 02:48 AM
Seattle
I may need to grab a close up picture of that area, but in mine there is only one inverter power outlet and it does not run behind the DVD plays, it’s on the wall of the cabinet, not in the little multimedia box they have. There are some cables running from a hole in the wall into the multimedia box where the DVD player is, but they are all black cables. One is the satellite coaxial connection.
07-03-2022, 03:17 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
You can also remove speaker to get to wires behind the radio.
07-03-2022, 04:56 PM
Seattle
Oh, good tip! That might be simpler. Thanks!
07-03-2022, 05:03 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
There are several 12volt circuits in the “entertainment center”.
07-03-2022, 06:27 PM
Seattle
Yeah, I was realizing there also must be 12-volt up there for the under cabinet lighting there.
