Old 06-08-2024, 11:59 AM   #1
2024 28' Flying Cloud
Bartlett , Tennessee
Removing Airstream Registry disk
I am trading in my 2017 FC23FB for a 2024 FC28RBTwin. I want to remove the registry disk off of my 2017. Does anyone have a way to remove it without scarring the trailer?
Thank you
Bobbo and Lin
2024 F-350 Crewcab 4x4 gasser
2024 Flying Cloud 28RBTwin
Bobbo is offline   Reply With Quote
Old 06-08-2024, 01:24 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
You could try dental floss or fishing line. I've used it before to remove items mounted with double stick tape. Hold it taut and slowly work it down behind the plate.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 06-08-2024, 01:34 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Spray WD-40 behind it to soften the glue, then use the floss, or a high E guitar string.
2019 Ford Expedition Platinum
Old 06-08-2024, 02:03 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have used fishing line to floss off items with success.
Richard
Old 06-08-2024, 02:27 PM   #5
Thanks. I will give these a try.
Bobbo and Lin
Old 06-08-2024, 04:41 PM   #6
Rich Jenkins's Avatar
2019 25' Flying Cloud
Ocala , Florida
Might not hurt to apply some localized heat to soften the glue with a hair dryer along with the dental floss?
Be sure and tell DW that it's "for my hair" when she asks you where you are going with her dryer.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Rich Jenkins is offline   Reply With Quote
Old 06-08-2024, 05:33 PM   #7
AirstreamJim's Avatar
2009 34' Classic
Lake Worth Beach , Florida
This is what I did. Hair dryer followed by fishing line. Cleaned off the little bit of residue with Goo-Gone.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 06-08-2024, 08:03 PM   #8
LOL. Will do.
Bobbo and Lin
Old 06-09-2024, 11:43 AM   #9
The fishing line broke, but I have a putty knife with the sharp corners rounded off with a grindstone. Heat, the putty knife, and GooGone took care of it.
Thanks everyone
Bobbo and Lin
Old 06-10-2024, 05:21 AM   #10
2018 30' Flying Cloud
Springfield , Ohio
Don't use tools behind the disk - aluminum is soft and easily dented.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 06-10-2024, 06:25 AM   #11
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
I was thinking E minor
bigfoot390 is offline   Reply With Quote
Old 06-10-2024, 07:03 AM   #12
Vermont Airstream "Maple"
Greggnvt's Avatar
2024 27' Flying Cloud
Franklin , Vermont
?? Registry Disk
What is a "Registry Disk"?
Thanks!
Greggnvt is offline   Reply With Quote
Old 06-10-2024, 07:12 AM   #13
Thanks!
https://www.airstream.com/name-your-airstream/
Bobbo and Lin
Old 06-10-2024, 07:52 AM   #14
2002 25' Safari
Dewey , Arizona
Images: 62
Shouldn't the medalion with the VIN and name remain on the trailer? Isn't it bad luck to rename an Airstream?
Richard
Old 06-10-2024, 03:07 PM   #15
Greggnvt's Avatar
Franklin , Vermont
I never knew about this - thanks for sharing!
Gregg
Old 06-11-2024, 12:06 PM   #16
Steamguy's Avatar
2024 19' Caravel
Washougal , Washington
Originally Posted by azflycaster View Post
Shouldn't the medallion with the VIN and name remain on the trailer? Isn't it bad luck to rename an Airstream?
We used to sail, and some sailors can be a very superstitious lot, and for them, renaming a boat is mondo bad luck.
If you do rename your Airstream, perform a 'de-naming ceremony':
This ceremony can be performed by writing the current name on a piece of paper, folding it, placing it in a wooden box, and burning it. The ashes are then scooped up and thrown into the sea.
Steamguy
2024 Caravel 19CB
"Dot"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 06-11-2024, 12:18 PM   #17
Wayne&Sam's Avatar
Images: 21
Smile
I guess you don't play guitar.
The E string would not have broken, like that flimsy dental floss!
However DO NOT use an E string as dental floss!
Old 06-11-2024, 12:20 PM   #18
Wayne&Sam's Avatar
Images: 21
Throwing the ashes in the sea might work for a boat, but shouldn't they throw their ashes on an interstate?
Old 06-11-2024, 10:20 PM   #19
Steamguy's Avatar
2024 19' Caravel
I think the people in the Interstate might object...?
Old 06-12-2024, 02:47 AM   #20
bigfoot390's Avatar
Chatham , Virginia
A simple campfire ceremony is sufficient. At least one flamingo and a bottle of rum is required.
Vacuum Disk Brakes APB Brakes & Brake Controllers 27 07-04-2019 10:33 AM
Airstream Disk Brakes and GM Controller ? woodfox45 Brakes & Brake Controllers 26 10-05-2015 08:02 AM
Registry - How do I add mine to AIR Registry? tomandjana97 Forum Admin, News and Member Account Info 1 07-07-2015 05:05 PM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 11:54 AM
