11-19-2017, 07:55 AM
Bentley
2017 23' Flying Cloud
St. Louis
, Missouri
Loud and rapid cycling water pump
I can’t find the thread so
In search for a solution.
From the docs.
PF Cardwell
23FB Flying Cloud
2017 F150 4X4 Super Crew
3.5 V6 Ecoboost 10-speed
11-19-2017, 07:57 AM
Bentley
St. Louis
, Missouri
More
PF Cardwell
23FB Flying Cloud
11-19-2017, 08:05 AM
Bentley
St. Louis
, Missouri
Shurflo kit 94-591-01
Might try this kit.
I do not know how to adjust pressure.
PF Cardwell
23FB Flying Cloud
11-19-2017, 08:14 AM
Bentley
St. Louis
, Missouri
I checked reviews on the kit I think I’ll make my own.
PF Cardwell
23FB Flying Cloud
11-19-2017, 09:04 AM
Bentley
St. Louis
, Missouri
PF Cardwell
23FB Flying Cloud
11-19-2017, 09:13 AM
Bentley
St. Louis
, Missouri
PF Cardwell
23FB Flying Cloud
11-19-2017, 09:16 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If your pump is as conveniently located as my pump ... first step might be to pull it out from under the fridge. You might well find that the rock (or whatever) simply shakes out once the pipes are off the pump.
11-19-2017, 09:21 AM
Bentley
St. Louis
, Missouri
Not sure what model he is talking about.
https://youtu.be/i3_rzV4Aa-4
PF Cardwell
23FB Flying Cloud
11-19-2017, 09:45 AM
Bentley
St. Louis
, Missouri
Adjust pressure.
PF Cardwell
23FB Flying Cloud
11-19-2017, 09:46 AM
Bentley
St. Louis
, Missouri
More plumbing.
PF Cardwell
23FB Flying Cloud
11-19-2017, 09:47 AM
Bentley
St. Louis
, Missouri
Will do in the early spring.
That’s all folks
PF Cardwell
23FB Flying Cloud
11-19-2017, 10:03 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by pfcardwell
Hi
It's more a generic video to give an idea of where the stupid screw is and how much to tweak it each time you fiddle the setting. It's certainly better than what we already had .... It also (via the gremlins of YouTube  ) links you into a long string of "troubleshooting your RV water pump" videos. Lots to watch all winter long
11-19-2017, 03:09 PM
Bentley
St. Louis
, Missouri
So in summary.
Airstream does not use flex hose, 1/2 inches piping and on my 23fb it elbows at the pump.
PF Cardwell
23FB Flying Cloud
11-20-2017, 08:52 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The plastic pipe they use is likely better for the application than a hose.... It will be a bit more noisy, but way more durable.
11-20-2017, 07:54 PM
2007 28' International CCD
Springfield
, Missouri
I got tired of the knocking and cycling loud water pump.Spent $120 and 15 mins on a Shurflo Revolution pump.No more knocking and cycling and more water pressure is a added bonus.
Mounted the old pump to a board and installed alligator clips with 1 ft of wire and bought 10 ft of clear plastic hose.Comes in handy for transferring fresh water to the water tank from 12 gallon containers when boon docking.I carry a portable jump box/compressor that powers it.
