Old 07-23-2022, 06:20 PM   #1
2020 30' Classic
Lasalle , Ontario
Looking at a Flying Cloud and have some ?s
Is there a year that would be better than others when looking at a flying cloud. Specifically I’m looking for a bunk unit although that may not matter to you folks. I heard they ditched the wood in the floor in these units but not sure what year that took effect. I’m in no hurry for a unit just looking for something by Christmas.
Thanks folks,
CS
Chad1383 is offline   Reply With Quote
Old 07-23-2022, 07:17 PM   #2
2020 23' Flying Cloud
2019 22' Sport
Sebastian , Florida
We were pleasantly surprised to find our 2020 23FB has the composite floor, as it was not advertised by A-S. They are known for using what is at hand in the parts bin, resulting in variation between trailers of the same model year.
I suggest you make a list of what matters to you:
Round vs. rectangular double sink
Ducted air (You would have to go back about six years to find unducted. Stay away from unducted unless you could sleep through a hurricane!)
Wood vs. composite flooring
Tank vs. continuous water heater
Absorption (propane) vs. compressor fridge
Flooded vs. AGM batteries
These are a few considerations. I’m sure others will chime in.
Then look carefully at the trailer you are considering to verify what it comes with.
Good luck!
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 07-23-2022, 09:01 PM   #3
Spaggs's Avatar
2022 28' Flying Cloud
GAINESVILLE , GA
If you can get a composite floor with a non-tankless water heater, you have hit the sweet spot, IMHO.
Spaggs is offline   Reply With Quote
Old 07-23-2022, 10:54 PM   #4
Dennis C's Avatar
Evergreen , Colorado
My 2020 23FB has a plywood floor. It was built in late 2019.
Dennis
Current: Newmar Ventana 3715 (6,265 lbs. cargo capacity )
Past: Airstream International Serenity 23FB
Dennis C is offline   Reply With Quote
Old 07-24-2022, 09:53 AM   #5
2016 25' Flying Cloud
Friday Harbor , Washington
Width
Check for width. Some models vary by as much as 8 inches.
Rob Cope is offline   Reply With Quote
Old 07-24-2022, 10:46 AM   #6
1988 32' Excella
Robbinsville , New Jersey
Power vs. manual awning.
Solar and how much solar, this matters for boondocking and uncovered storage.
For batteries some may also have been converted to lithium.
Old 07-24-2022, 11:24 AM   #7
2015 27' Flying Cloud
Truckee , California
100% agree with this!
We went from a 2016 FC to a 2021. Glad we got the composite floor, but lukewarm (pun intended) on the tankless. We don't boondock much, so it's not a huge issue, but if you do, you will find you will use so much water taking showers with the tankless.
SGandMT is offline   Reply With Quote
Old 07-24-2022, 12:12 PM   #8
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
Thanks folks,
CS
Depends on how you'll use it, what you like or dislike, etc.
2015 was the year that the twin-axle models got the ducted A/C (my single-axle 2015 has the older style of A/C); yeah, it's louder, but, even my wife doesn't complain, she equates it to white noise (she'd pick cheaper every time anyway). The composite floor came in 'approximately' in the changeover from 2020 to 2021... but sometimes, in a factory situation, you might find early one-offs, or perhaps a later 'using up the last of'. I would have liked the composite floor, but, not enough to trade up for a lot more expensive newer model (again, the wife votes to keep the older less-expensive one). Also, we like our older FC interior, the way the wood looks, the cabinet doors, etc.; a brand-new FC has a revised interior look that, while functionally fine, we prefer ours.
We like our propane/electric fridge; newer ones can't run on propane. We like our water heater having a tank instead of a tankless like the latest ones have.
On the older ones: there are many fine ones out there, but when I was still hunting for an Airstream, there were quite a few that I ended up passing over because of soft spots in the wood floor at the back, where the bumper is attached. Water would infiltrate, and there goes the floor. It's fixable, but, needs to be fixed; that would be a reason why composite would be a good thing.
-Leslie
WBCCI #1051
LNBright is offline   Reply With Quote
Old 07-24-2022, 02:35 PM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Not all 2015 models got the oversized holes in the ceiling for their air registers to fallout out of when moving. Our 2015 23D International Serenity is pre-duct and we searched for that.
We have installed the New Coleman 15K BTU units with MicroAire Softstart kits and they are much quieter than Dometic units. One can actually converse without yelling.
The German brand Truma company that makes tankless instant on propane only water heaters is building a new generation of ceiling A/C unit that is nearly noiseless. Winnebago gets the early ones but should be availble to retrofit in early 2023.
A rule of thumb is that recent Airstreams 25' or longer will be 8' 6" wide and the shorter ones are 8' 0" wide. There were two nominally 23' models until last year so there is just a front bed model now.The 23' size was the entry model to dual axles.
Old 07-24-2022, 04:19 PM   #10
2019 25' Flying Cloud
Greeneville , Tennessee
We may have a confusion of terms. Mine is a non tankless water heater, meaning it has a tank.
jimfa440 is offline   Reply With Quote
Old 07-25-2022, 10:09 AM   #11
2020 30' Classic
Lasalle , Ontario
Thanks everyone for the comments. Im in the market for a 30 bunk. I have been looking at 2019 units. Do we think pre pandemic units may be built better?
Old 07-25-2022, 10:14 AM   #12
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Be SURE to get ducted air: 2015 and newer ...
2015 25' Eddie Bauer Int'l FBQ / 2020 Ford Expedition 3.5 EB
AIR# 44105; formerly WBCCI 2015.1
Old 07-25-2022, 10:15 AM   #13
jaybauman's Avatar
2021 33FB Classic
2019 30' Flying Cloud
Katy , Texas
I had a 2019 FC30Bunk built in late 2018. We spent 1.5 years getting all the bugs worked out. Once we did, it was great.
I now have a 2021 Classic 33 built in late 2020. We have spent 1.5 years getting all the bugs worked out. Our last few trips have been great!
People can speculate, but I have 1 data point that says pre/post pandemic doesn't seem to matter.
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
jaybauman is offline   Reply With Quote
Old 07-25-2022, 12:12 PM   #14
LNBright's Avatar
Well, sounds like there's exactly the right person to respond.
Get one, whichever you get, then work the bugs out of it, whichever it is.
-Leslie
WBCCI #1051
Old 07-25-2022, 03:18 PM   #15
jamieb1086's Avatar
Selbyville , Delaware
I have a 2016 Flying Cloud and the only thing I would want that the newer models have is the composite floor. And LOVE the manual awnings!
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Delmarva Unit
jamieb1086 is offline   Reply With Quote
Old 07-26-2022, 11:57 AM   #16
2022 30' Flying Cloud
Vancouver , British Columbia
I just took delivery on a 2022 Flying Cloud 30 Bunk. Well, almost. The dealership is correcting some issues we turned up on the walkaround, and ran out of time to finish the work on our initial delivery day. Hopefully we drive off with it tomorrow.
If you want something by Christmas your options are be very fortunate or purchase a used model you find, we waited 11.5 months for our order from the factory.
Older models have some notable differences:
- Rounded cabinets with a wood laminate, I think 2021 forward they are now flat grey with a gloss finish, and next year they will be matte white.
- 2021 or 2020 has the composite floor
- 2021 onward converts to a single rectangular sink, from a single round sink.
- 2021 (I think) the shower shape changed from a molded seat to a removable seat
- 2017's had a stainless steel stove cover that wasn't flush to the counters, at some point they switched to flush glass covers.
- By 2021 they switch from an accordion door over the master bedroom to a curtain. Not sure what year this changed
- In 2016 the 2nd Air Conditioner (and I assume 50amp) was an option, it became standard some time after that
- 2021 on upgrades the solar charge controller to a Victron model
- 2019 on seems to be when they added the solar rock guards to the sides of the front cap. Prior to that it was a single lexan window as standard
- 2022 switches from an 8 cu. ft. propane fridge to a 10 cu. ft. compressor fridge. As a result the access panel on the side and the exhaust hood on the roof disappear as well.
- Some where between 2017 and 2021 they changed the logo from the blimp style design to the cursive writing
- 2021 or so is when they flip from a hot water tank to tankless, I think.
- 2022 ditches the exterior scare light.
There are other differences in switch gear, LED light white color, and other minor things along the way.
Good luck in your search!
jlydell is offline   Reply With Quote
Old 07-27-2022, 09:31 PM   #17
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
the AS site now shows 2023 model
but, the d/l brochure still only shows it as 2022
when do they start making the 2023?
are new FC 25Fb is being made the 2nd week of aug/22 will it be the old 22 or the new 23
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
waninae39 is offline   Reply With Quote
Old 07-28-2022, 09:59 AM   #18
1988 32' Excella
Most vehicle manufacturers, cars, trucks and RVs (including trailers) seem to average starting to get the new model year to dealers in August. That doesn't mean all models or every year though just the average or the norm. One example I saw a 1998 Ford F-150 on the road in December 1996, rushed into production to early to use in Nascar truck series in 1997.
This means any answer you get is just a guess.
So my GUESS is it would be a 2023.
Old 07-28-2022, 10:07 AM   #19
2023 28' International
Mercer County , New Jersey
As others have said, it's a "depends" kind of issue but Airstream usually completes the cutover by the end of July. That said, there are frequently stragglers for some models/trims that may lag behind.
I'd suggest you call Airstream and they'll be able to tell you exactly what you are getting.
Also, if you have the VIN, it should have the year included as part of it.
jeffb831 is offline   Reply With Quote
Old 07-28-2022, 11:48 AM   #20
switz's Avatar
2014 31' Classic
The annual model cut over date historically was 1 July
A ponder - Would Have,Could Have ,Should Have Life is a Highway Towing, Tow Vehicles & Hitches 37 11-01-2019 07:55 AM
Some GFI protected circuits work and some don't. Two Peas On The Road... 21 02-02-2016 04:27 AM
New to Airstreams Looking to buy our first one. Have some questions. RichC General Motorhome Topics 4 06-27-2013 08:07 PM
Some progress and Some Questions SCopp 1970 - 1973 Overlander 3 02-03-2013 07:25 AM
I am new a member and I have some questions wol Repairing/Replacing Floor &/or Frame 7 09-22-2004 09:17 PM
