Old 10-22-2022, 10:42 PM   #1
Cleveland , Tennessee
Location of the inverter/power (nerve) center for 2023 FCFB?
Said unit hasn't been manufactured yet, the one I have on order. I hastily purchased the slightly larger size 206Ah batteries (Lifepo4) before realizing they're not going to fit in the battery box. I want to put them inside anyway, under the front queen bed. I also didn't realize I was bitting off more than I could chew, as it seems this isn't a simple install/relocation. How accessible is the power center to work around and hook into? Any experienced insight would be appreciated.
koberudy is offline   Reply With Quote
Old 11-26-2022, 06:39 AM   #2
2022 27' Flying Cloud
Wapakoneta , Ohio
What length is your Flying Cloud going to be? I just took delivery of a 2023 27' FBQ and the "nerve center" appears to be under the curb side nightstand. There is a small access door from within the outside storage, but otherwise it is pretty inaccessible without removing things.
I too was wanting to get into that nest of wires to add in a smartshunt and after some quick eyeballing it appears to require some thought on getting access. My Caravel that we just traded in had a nice big access door so it was easy to see and work on everything.
I haven't quite figured out how to remove the nightstand to get a good working space, but the weather hasn't been great here so just haven't put a lot of time into it yet.
My guess is you'll have to place those batteries in the outside storage compartment or use up space under the queen bed.
Good luck!
jagpanzer is offline   Reply With Quote
Old 11-27-2022, 12:31 PM   #3
There seems to be enough space available under the queen bed, not within the partitions where the compartments are (ie: plastic bins). There's another partitioned area under there that runs across the bed's width, near the wall (top of the bed), but not the space of the only outside storage compartment.
Ordered a 2023 FC 25FB- wont arrive until spring 2023 waninae39 2016 - Current Flying Cloud 48 07-17-2022 06:39 AM
Searching for 1st Airstream (first travel trailer) 23'FCfb Popsx4 Buyer Guidelines 0 02-14-2021 05:19 PM
2021 Silverado 5.3 vs 6.2 & 2021 25' FCFB Dr. Ohat Towing, Tow Vehicles & Hitches 32 12-30-2020 12:46 PM
27 FCFB for boondocking? jcrango Boondocking 23 01-19-2016 11:49 AM
Do I have the nerve? Flysoncloud Upholstery, Blinds, Walls & Interior Finishes 3 04-10-2011 06:01 PM
