Old 05-14-2021, 04:39 PM   #1
2020 27' Flying Cloud
Decatur , Michigan
Jack it bike rack
Has anyone had trouble fitting the Jack It bike rack on the front of their trailer? These are in very short supply and very difficult to get. Well I persisted and I was able to get one for my 2020 flying cloud. Our flying cloud has the hatch on the back so I needed a bike rack up front. The jack it bike rack looked like it would be perfect but when I got it home and unpacked it the lower frame piece that goes around and over the jack was 22.5 inches inside where the jack goes. Even though my jack is a Lippert 4000 pound electric jack and this bike rack is from Lippert- the jack is 26” tall and the two will not fit into the same space. I contacted the manufacturer and they are aware of the issue and told me they do no make a taller one and I would have to buy a smaller jack to make it work. Instead of spending 400+ on a new jack I went to steel supply company and got plenty of steel to make it taller. Got all the pieces cut and fit today. Will weld and paint tomorrow.
ID:	395495   Click image for larger version
ID:	395497   Click image for larger version
Bob May is offline   Reply With Quote
Old 05-14-2021, 06:51 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I wish I knew how to weld. Great skill. Nice work!
wulfraat is offline   Reply With Quote
Old 05-14-2021, 06:58 PM   #3
Decatur , Michigan
I think I will do another modification
The original design has the bike holder cantilevered over the propane tanks. I think loading would be much easier if it was straight up or turned forward. Tomorrow when I get up I will make a straight one.
ID:	395508   Click image for larger version
ID:	395510   Click image for larger version
Old 05-15-2021, 12:39 PM   #4
Decatur , Michigan
All welded up - ready for cleanup
Used Lincoln SP-130T - worked great very sturdy
Old 05-15-2021, 01:40 PM   #5
Decatur , Michigan
Cleaned up and in paint booth ready for paint
Just need to mask it off.
Old 05-17-2021, 10:36 PM   #6
Decatur , Michigan
Bottom installed on trailer
After modifying the length of the Jack-It bike rack bottom section I put it on the trailer. Around and over the jack. Fit good and now I will setup and figure the top section tomorrow.
ID:	395693   Click image for larger version
Old 05-18-2021, 05:27 PM   #7
Decatur , Michigan
Completed second modification to bike rack
Converted the offset of the bike rack to straight up. My thought here is that it will allow propane bottles to be swapped without disassembling any part of the bike rack. Also to address the negative feedback of some individuals that the bikes have to be lifted high up to connect. With the new straight up piece I will be able to put my tailgate down and easily load and unload the bikes on the rack from my tailgate. It also supports opening the front window outer protector/awning.
ID:	395735   Click image for larger version
ID:	395737   Click image for larger version
Old 05-19-2021, 04:46 PM   #8
Decatur , Michigan
Bike rack modifications are done.
Completed and assembled today and put bikes on. Easy to do from tailgate of tow vehicle. Plenty of room to the front of the trailer and good access to propane tanks. Making the bike holder go straight up also makes it easy to load from truck tailgate. Much improved design for the airstream.
ID:	395777   Click image for larger version
Old 05-21-2021, 05:53 PM   #9
California Flying Cloud
52HalfTon's Avatar
2018 25' Flying Cloud
Camarillo , California
Beautiful work. No concern about the loss in aerodynamics?
52HalfTon is offline   Reply With Quote
Old 05-22-2021, 05:16 AM   #10
Decatur , Michigan
Not sure
We have not taken it out on the road yet but you pose a good question. We are off to Colorado in 3 weeks and I will have to see the impact. I am assuming that most air will flow thru the bikes. The trailer did pull exceptionally well before the add.
installing bike mount bike carrier ClaireBambi Hitches, Couplers & Balls 72 12-12-2020 05:03 PM
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
