Old 05-02-2020, 06:06 PM   #1
Backfortyjoe's Avatar
2019 20' Flying Cloud
Eau Claire , Wisconsin
Fantastic fan rain sensor
Howdy to all,
We have a FC 20í FB and was told by the dealer that the rain sensors were no longer connected since there was a lot of problems with them. To our surprise it was working and didnít work the way it should. It will not stay open in the evening and will not open until the dew is bone dry in the mornings. I was wondering if anyone has disconnected their sensors. I would like to fix this myself as the dealer is quite far. Sorry if there are posts on this as I suppose there are many but I cannot find my way around this website very well. Thanks for any help that you may provide.
Best Regards, Joe
Backfortyjoe is offline   Reply With Quote
Old 05-02-2020, 06:47 PM   #2
Malia20's Avatar
2017 20' Flying Cloud
Oriental , North Carolina
We have the same problem with one of our FF vents. Fixing it is on the list. You might start here...
https://www.airforums.com/forums/f37...on-136539.html
Other posts can be found with a google search like
"disconnect fantastic fan rain sensor site:airforums.com"
Good luck!
Fred
Malia20 is offline   Reply With Quote
Old 05-02-2020, 06:52 PM   #3
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Originally Posted by Backfortyjoe View Post
Howdy to all,
Best Regards, Joe
Hereís a picture that should help. I think I just unplugged mine from the board.
Hiho Silver is offline   Reply With Quote
Old 05-02-2020, 07:33 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I cut the wires on one because I couldn't figure how to pull the connector. I figured it out on the second one. There is a locking tab that has to be depressed to pull the connector from its mate on the circuit board. That is all you have to do to stop the up/down/up down from dew.
Al
ďYou cannot reason someone out of a position they have not been reasoned into"
Old 05-02-2020, 07:44 PM   #5
2024 28' Flying Cloud
Bartlett , Tennessee
I didn't want to cut wires in case I wanted to restore it to original configuration. There are about 6 screws (if memory serves) and the plate inside the RV will drop down and dangle from the wiring. Unplug the rain sensor from the circuit board, and put the plate back up with those screws. Be sure the knob syncs with its gear. It is an easy 10 minute job.
Bobbo and Lin
2024 F-350 Crewcab 4x4 gasser
2024 Flying Cloud 28RBTwin
Bobbo is offline   Reply With Quote
Old 05-03-2020, 07:53 AM   #6
Thanks to all of you, I was hoping to be able to disable it without crawling on top of the trailer and it sounds from the most of you that it can be done from the inside. I will give it a try later this week as it is stored now a ways away from where we live.
God Bless and be safe. Joe
Old 05-03-2020, 09:40 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Cleaning the sensor helps a bit, but morning dew still activates it.
2019 Ford Expedition Platinum
Old 05-03-2020, 10:01 AM   #8
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Hearing these problems makes me even happier that my "b" has the Maxxfan.
rowiebowie is offline   Reply With Quote
Old 05-03-2020, 10:33 AM   #9
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I believe you can pull down on the knob to make the fan run manually. Never tried to see if that would defeat the rain sensor. Try it - if it works you are golden.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-03-2020, 10:39 AM   #10
2012 23' FB Flying Cloud
Woodstock , Ontario
Pat
You are correct, Pat. I often use this feature to manually control the fan.
terrythomts is offline   Reply With Quote
Old 05-03-2020, 10:52 AM   #11
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Yep, thatís what I do.
banderabob is offline   Reply With Quote
Old 05-03-2020, 11:19 AM   #12
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Disengaging that knob has never worked for me or maybe Iím missing something. When sensor is moist/damp/wet that little motor thing runs constantly. Iím thinking of disconnecting the sensor as well since I only keep the vents on when Iím around or if we are certain of no chance for precip.
crazylev is offline   Reply With Quote
Old 05-03-2020, 12:12 PM   #13
oldfulltimer's Avatar
1993 34' Excella
Randolph , Vermont
At least on the older Fantastic Fans, to overcome the morning dew problem, we'd tell the owners that before going to bed, bring the fan to close, then open it back up. When it gets open about two to three inches, grab the up/down motor knob and simply stop the motor from turning. Don't pull down on the knob, just stop it from turning.
The fan will be running but the lid will not be fully open and when the fan stops after the temperature has cooled down, dew will not settle on the sensor because the lid is over it. If you stop the lid on the way down, the rain sensor will be disabled and won't close in a heavy rain. Always stop the lid on the way up. And BTW, if you open the fan and then turn the speed knob to "0", power to the fan is turned off and if it rains, the fan will not close. Always leave the power setting on something other than "0".
oldfulltimer is offline   Reply With Quote
Old 05-03-2020, 01:07 PM   #14
2019 25' Flying Cloud
Hendersonville , North Carolina
FF Rain Sensor
First mod I made on our 2017 International and now our 2019 FC 25 was disconnecting the rain sensors on both fans. Maybe 5 or 10 minutes per fan. Easy peasy. Second mod was installing the FF "Ultrabreeze" covers on both fans with the optional bug screen (separate part). Took maybe 20 minutes per cover to install. No more fan closing just when you need it most. We leave our fans open most of the time. It has to be raining really hard and the wind blowing just right to have any water droplets come in after installing the FF "Ultrabreeze covers. We choose white ones. Happy travels.
uraljohn is offline   Reply With Quote
Old 05-03-2020, 01:22 PM   #15
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
like many devices, you need to keep the sensor clean. a lot of dirt builds up, some of it is semi-conductive.
clean carefully and the senor will work again as advertised
waninae39 is offline   Reply With Quote
Old 05-03-2020, 01:39 PM   #16
Wayne&Sam's Avatar
Images: 21
One of the first mods I make is to replace the FFs with MaxxAir fans.
Old 05-03-2020, 06:29 PM   #17
Yes, it is done from the inside.
Bobbo and Lin
Old 05-03-2020, 06:41 PM   #18
"Cloudsplitter"
Take a green scotch pad & WD40 clean the rain sensor, wipe dry with alcohol, (Aqua Velva werks gud).🤔
Iím done with ĎadultingíÖLetís go find Bigfoot.
Old 05-03-2020, 11:43 PM   #19
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
After I installed vent covers I didn't have the problem anymore and I can leave the fans to automatically do their thing with no false triggering with morning dew.
gandttimes is offline   Reply With Quote
Old 05-04-2020, 05:33 AM   #20
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I had to go look at my fans to be sure but I remembered....my fans actually have a switch to turn off the rain sensor. A rocker switch with a red label on one end to warn you that it is off. Clearly I rarely use the switch, especially since I have a cover over the salon fan. My trailer was built in 2012. Do the new Fantastic fans not have the switch?
Larry
lsbrodsky is offline   Reply With Quote
Fantastic Fan - Rain Sensor Not Working jbroedlow Roof Vents, Skylights & Fans 6 05-15-2016 03:43 PM
Fantastic Fan Rain Sensor Issue Candominium General Repair Forum 2 11-07-2015 01:48 PM
Fantastic Fan rain sensor location? brad1 Electrical - Systems, Generators, Batteries & Solar 25 07-27-2015 10:22 PM
Fantastic Fan Vent rain leak???? jvcolaizzi General Repair Forum 1 09-01-2014 11:26 AM
Rain, Rain, Rain knunut Off Topic Forum 12 01-10-2013 07:25 PM
