06-13-2021, 11:46 AM
#121
Alamo Heights
Originally Posted by pmclemore
I sometimes run my Dometic off the inverter - works fine but is a power hog.
Are the new AC fridges more efficient? They would have to be for me to ever choose one.
Pat
You're talking about a propane-electric Dometic? Danfoss compressor fridges are VASTLY more efficient than the electric side of an ammonia-absorption fridge. Why would you run a propane-capable fridge off an inverter?
— David
06-13-2021, 12:29 PM
#122
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by DKB_SATX
They probably worked better with the ice in the top compartment, like in a home icebox.
Hi
Might have, except the door was on top. If you put the Ice in after the food, pulling the giant block out each time would get old really fast ....
06-13-2021, 12:30 PM
#123
Lynnsr
2018 20' Flying Cloud
Colorado Springs
Originally Posted by Tablerocked
“Sufficientmy clean”? Last I checked less than 10% of our power comes from non-fossil fuel sources….. closer to 6%.
Electric cars are coal powered and natural gas powered vehicles.
Ditto, Refreshing voice of reason.
And if that changes dramatically you had better learn how to walk, south.
Lynn
06-13-2021, 12:50 PM
#124
Alamo Heights
Lynn
A voice of disinformation.
Nuclear alone accounted for about 20% in US in 2020 (per US government link above) and renewables another 20%.
— David
06-14-2021, 04:52 PM
#126
2016 28' International
Trois-Rivieres
, Quebec
On my Dometic refer sticker, it is indicated that it pulls 2.7 amps at 120V. That's 324 watts off the 1000W inverter, or 27 amps off the battery bank or from the solar controller.
My solar panels (500W) give me up to 40 amps on a bright sunny day, so it would be theoretically possible, on those days, to run the absorption fridge off the solar panels and not draw down the batteries. At night that is another matter...!
We love to camp up North in the Fall when it is a lot cooler and can be cloudier, so we need the propane option. The ultimate solution would be a hybrid fridge: absorption when running on propane, and with a compressor when running on electrical power.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
06-14-2021, 08:13 PM
#127
1994 25' Excella
Waukesha
, Wisconsin
Talk to the guys at JC Refrigeration. They are the ones that make DC compressor cooling units to replace absorption units. I bet they could make one that had dual cooling.
Richard
11018
06-15-2021, 12:58 AM
#128
Sag Harbor
, New York
Originally Posted by N95556
I'm in the market for a new 30' Flying Cloud and the salesman is telling me that the new FC fridges will be electric only, starting in 2022 but it may have already started in 2021 models? I haven't seen this online and the Airstream brochure only says "two-way".
Can anyone confirm/review the new fridge? Is it really all electric? Is it bigger on the inside since it doesn't have the absorption components? Did airstream remove the external vents?
Thanks in advance for the help and assistance on my first post in this forum!
Wondering if you [OP] have received all the info you need from this thread? Your last post here was in May, about 2 weeks ago.
Happy trails,
Peter
06-15-2021, 05:05 AM
#129
Happy trails,
Peter
Ha not really but I’ve enjoyed the discussion regardless.
My main question is about what fridge will be included in my AS thats due to deliver in 3-4 months. It’s surprising that there’s not much info about it and the 22 models should be rolling off the line next month.
06-15-2021, 06:05 AM
#130
Sag Harbor
, New York
Thanks.
06-15-2021, 06:49 AM
#131
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Other than the Interstate X, none of the 2022's really have firm specs. One would *guess* that organizing the X stuff had the marketing folks pretty distracted.
Even the dealers (who normally have pretty good info) don't seem to know when the official 2022 specs. brochures, price sheets .... will start popping up. Early to mid July maybe ..... who knows ....
06-15-2021, 07:35 AM
#132
2022 25' International
Savage
The list from Woodland when we ordered our new 2022 International:
- 12v/110 Fridge - 2022 upgrade
- Smart Plug - 2022 upgrade
- Lithium Compatible Converter - 2022 upgrade
- Composite Floor - 2021 upgrade
-Tankless Hot Water - 2021 upgrade
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
06-15-2021, 02:24 PM
#133
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
I have plenty of solar (600w) and 480wh of lifepos. I find running the refer off the inverter better than propane down the road. Also helps when I go through our bridge tunnels.
But that was my question - are the new ones much more efficient? I hope so, if they are the future. As I said, the propane-electric refers are power hogs. Your answer indicated this is the case.
BTW - when Lewster installed my system, he asked if I wanted to go with one of the new ones, but by that time my bank account was tapped out.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
06-15-2021, 03:10 PM
#134
Alamo Heights
Pat
Shooting from the hip I'd say the 120v side of an absorption fridge requires about 5x the power to run. It's about 2.7A at 120v (325W), where an 8-ish cubic foot compressor fridge wants about 5A, but at 12V (60W)
— David
06-15-2021, 03:24 PM
#135
Sag Harbor
, New York
Wondering if you [OP] have received all the info you need from this thread? . . .
So . . . after 135 posts in only 2 weeks, this thread will not have an answer to your OP question, until sometime after Labor Day, and perhaps another 1,000 posts, when you can see in person what exact fridge was installed at the factory?
06-15-2021, 03:31 PM
#136
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I'd bet at least a bottle of beer that we'll know what's what by mid July. Not that this is how it should be .....
06-15-2021, 03:34 PM
#137
Sag Harbor
, New York
With 100% absolute certainty? Or "probably" . . .
You're on . . . for the "100% certain" wager.
San Miguel Dark.
06-15-2021, 04:07 PM
#138
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
San Miguel Dark.
Hi
I'm saying that the official Airstream sheets / brochures will be out showing what's what on the models. They are normally the "standard" used to describe the RV.
Given that this is Airstream, there *never* will be 100% certainty, even after they publish all the specs
We certainly can have San Miguel Dark sitting here ready for you. We also normally have about 6 or 7 beers on tap.
06-15-2021, 04:12 PM
#139
Sag Harbor
, New York
Given that this is Airstream, there *never* will be 100% certainty, even after they publish all the specs . . .
06-15-2021, 05:31 PM
#140
2020 30' Classic
Frederick
, Maryland
I just want to defend people like myself who own an Airstream but 1) live on the east coast where the boon docking spots are not at all like out west and 2) have to work still so I cannot spend weeks and weeks cruising around the country with our trailer. So most of the camping we do is 4-5 days in state parks with power but rarely water or sewer. But that is good because it is hot and humid here and if we wanted to deal without AC we'd just pitch a tent and call it good. Face it; we are in tin cans costing tens of thousands of dollars with stoves and showers and toilets and heaters and air conditioners and Televisions! We are all "glamping". Sure I would like to be back out west because boon docking sites are much more common and interesting. But I cannot for now.
So no, boon docking requiring 2 weeks of battery life are not a big deal to me. We do one long trip per year, between 1-2 weeks, but we stay at campgrounds in the SE. We go to a place with hook ups. Does that mean we are not "real" Airstreamers? Face it; they are a large company and certainly did their homework before making changes so I am pretty sure that most of the buyers are like me. Sorry if we screwed it up for you all who want rugged outdoors plus your TV but hey, I am okay with it :-) Maybe you are right; no more AS for your because you are no longer their demographic.
For the record, I also appreciate the ability to run my fridge and water heater off of propane.(we have only used our oven once or twice; we rarely use ours at home, either. We cook in pans). But I solar is getting better, batteries are getting better; I am hoping that by the time we retire and upgrade to a different AS they are sufficient to let us hang out in the wilds for a week, anyway!
Be safe, have fun, and I look forward to what the OP figures out!
