11-09-2017, 02:44 PM
some town
, PA
Antifreeze in black tank flush?
I’m a newbie winterizing for the first time. I’m using on of the Camco hand pumps.
I’m wondering if it’s typical to pump antifreeze into your black tank flush?
Thanks!
11-09-2017, 02:53 PM
2017 30' International
Broomfield
I do.
I poor a gallon into the black tank to ensure that the valve where you connect your discharge hose does not freeze.
11-09-2017, 03:04 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Thanks!
I would recommend pumping some RV anti-freeze through the black water flush fitting on the outside of your trailer (as well as using air to blow out any water in the fitting.)
Ray B.
11-09-2017, 03:28 PM
2024 28' Flying Cloud
Bartlett
, Tennessee
Yes. Any water in that hose/fitting can freeze too. Or, just blow it out.
Bobbo and Lin
2024 F-350 Crewcab 4x4 gasser
2024 Flying Cloud 28RBTwin
11-09-2017, 03:54 PM
Kensington
, Maryland
11-09-2017, 05:25 PM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
Originally Posted by wulfraat
I do.
It won't freeze if you leave it open.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
11-09-2017, 06:46 PM
Bartlett
, Tennessee
No, but you risk getting rodents building a nest in there. It has happened.
Bobbo and Lin
11-09-2017, 08:00 PM
Walnut Creek
I think your question was answered above by several folks as yes. For anyone who believes the question is about the dump valves, it is not. Does the "black tank flush" need AF, was the question. That is the hose connection that uses shore water to flush the tank clean when it is dumped. Folks have reported the internal fittings have failed when water remained in that circuit and froze. I assumed there is a backflow fitting to keep waste from entering the shore water source, but have never looked at the schematic. Not sure what the proper method would be, but pumping it full of AF and blowing it out should work. Pat
11-09-2017, 08:17 PM
some town
, PA
Thanks for all the reply's. I've taken your advise and pumped some antifreeze through the black tank flush fitting in anticipation of freezing weather here in Philadelphia tomorrow night.
Really appreciate this community and all the good advise for this newbie. Thanks!
11-10-2017, 08:49 AM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
You are set. There is a backflow valve inside the coach that won't necessarily drain completely and will have water left in it. This is the failure point. It's a cheap clear plastic valve, on most any trailer you can see it usually if you look at the interior wall opposite the exterior fitting. Sometimes it's easily accessible, and you can just unscrew the fittings to manually drain it. But blowing with compressed air or pumping anti freeze will cover it.
12-03-2017, 05:56 PM
2018 30' Flying Cloud
Livingston
This will be our first winter as new Airstream owners and after reading this thread, I realize I need to do this also. We just winterized last week but did not focus on this flush point. What is the best way to "pump anti freeze" into this black tank flush connection?
Thanks!
Chris & Gina Fox
12-03-2017, 05:58 PM
Oswego
That's one line I just blow out well. It's short and mostly vertical lines. Never been a problem. Trailer has been through 11 winters.
-Rich-
12-03-2017, 06:49 PM
Bartlett
, Tennessee
I just blew mine out, but if you want antifreeze in there, attach a short hose to the connection, hold the hose upright and pour antifreeze into the hose using a funnel.
Bobbo and Lin
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Black Tank, Grey Tank, New Tank, Old Tank
Bunkroom |
Waste Systems, Tanks & Totes |
3 |
07-22-2014 08:35 PM |
Winterize, Pink Stuff, RV Antifreeze, Drain and Flush
masseyfarm |
Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes |
12 |
11-19-2013 06:40 PM |
Fresh Tank to Black Tank Flush (Spray)
withidl |
19 |
05-23-2011 05:41 AM |
Black Tank Flush System
Ed L |
Our Community |
6 |
02-19-2003 08:36 AM |
Black Water Tank Flush-Install
JaceBeck |
0 |
04-30-2002 11:54 AM |
