RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-25-2020, 09:46 PM   #1
2020 28' Flying Cloud
North Oaks , Minnesota
AGM battery winterization
Greetings and thanks in advance.
I have a 2020 FC with Lifeline AGM and solar package. I am confused about how to properly winterize these batteries. I live in MN, non heated indoor storage with plug in. Will the 2020 Airstream 3 way converter prevent overcharging? Or am I best to remove and put on trickle charger?
JustRehabIt is offline   Reply With Quote
Old 10-26-2020, 08:55 AM   #2
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
My AGMs have been fine for two winters left in the trailer. No solar; I just plug in to 30a for a day or so once a month.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 10-26-2020, 03:02 PM   #3
2018 30' Flying Cloud
Springfield , Ohio
AGM batteries don't require any special treatment in storage other than making sure a charge is maintained. A discharged battery can freeze and burst the battery case. Attaching a battery tender is a good choice if you can plug it into a wall circuit and leave it running. A second alternative, as discussed above, is to charge the batteries once a month to maintain the charge. Be sure the LP gas detector is either off or the batteries disconnected from the trailer if it cannot be turned off. By default, the LP detector still runs when the battery disconnect switch in the trailer is switched off. Battery Tender link shown below.
https://www.amazon.com/Battery-Tende...a-434255813726
tbrowne is offline   Reply With Quote
Can I replace 12V AGM battery with 12V deep cycle battery? iainmcc Batteries, Univolts, Converters & Inverters 10 06-06-2020 09:05 AM
13.65? Agm Battery charging, plus battery monitoring question Mx468 Electrical - Systems, Generators, Batteries & Solar 1 05-08-2019 10:24 PM
OEM Mercedes wet battery to AGM battery Mikemdd Sprinter and B-van Forum 22 05-02-2019 06:43 AM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 06:35 PM
AGM battery question LuminumTraila Batteries, Univolts, Converters & Inverters 3 03-01-2005 05:56 AM
