Old 07-06-2020, 04:25 PM   #1
2020 25' Flying Cloud
East Ridge , TN
A/C leaking in bedroom?
We have water dripping along the seam above one of our beds on our 2020 25fb with 2 a/c. It starts around the vent and is dripping all the way back to the bathroom(about 3ft). When I press up on the seam it pours out. It hasn’t been raining, it’s just hot and the a/c has been running nonstop. Thinking it has to be the front a/c drain or something? Think I saw someone else post about this not too long ago but can’t find it now.
mrbooshay is offline   Reply With Quote
Old 07-06-2020, 04:54 PM   #2
2016 25' Flying Cloud
z , Texas
Is water dripping out of the tubes on the curbside above each tire? If not try and put a shoo vac on it and suck it out, just my 2¢
5150mike is offline   Reply With Quote
Old 07-06-2020, 05:05 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
If condensate isn't coming out the drain tube and you suspect a clog, get piece of stiff weedeater line and run it up the tube.
CRH is offline   Reply With Quote
Old 07-06-2020, 05:26 PM   #4
2015 28' Flying Cloud
Newtown , Pennsylvania
Make sure the filters are clean.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
400ah LiFePo4, 800 watts solar, 2x eu2000i Propane
PD9160 converter, Prosine 1800 inverter
2x Victron 100/30 Smart Solar, Victron Smart Shunt
AstroBruce is offline   Reply With Quote
Old 07-07-2020, 02:52 PM   #5
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
On older A/Cs the drain pan can crack causing the same symtoms. They were replaced with a better design that isn't supposed to crack. Maybe your unit got and older A/C or the new ones are starting to crack. Airstream takes the unit off the roof to change them so the labor is expensive. You may be able to find a friend who can help you. I believe the crack could be stop drilled and then repaired with JB Weld. If you have a new pan on hand an R & R would save you time.
guskmg
Old 07-07-2020, 03:24 PM   #6
Boogieshoes's Avatar
2016 30' Classic
Little Rock , Arkansas
Had the same issue in our 2016 Classic in the bedroom. Virtually all RV A/C leaks are condensate line related. As someone else noted, check the condensate drain (should route down in the wheel well) and see if it is draining. If not, or if just barely dripping, you may have a clog in the line. In my case, there were two problems: 1. Rear A/C had been replaced (under warranty) and the drain cup under the unit was partially open to the outside; crud got in an clogged the line. Cleared by blowing air through the line from the bottom using an air compressor. (also, had the dealer re-install the unit so that the drain cup was sealed from the top). 2. Adhesive holding plastic routing hooks holding condensate line above the ceiling had come loose, making a couple of low spots along the routing in the ceiling before reaching the vertical drain line to the wheel well. Found this by pulling down the return air filter housings; gave me a good view of the condensate line and allowed me to fix easily. No more problems. Hope this helps; good luck!
_________________________________
Boogieshoes, DH of JudyJudy; AS "Rose"
WBAC 5932Arkansas Razorbacks Unit
2016 F250 KR 6.7 4x4 CC "Tex"
Members, NTAC
Boogieshoes is offline   Reply With Quote
Old 07-08-2020, 09:24 AM   #7
lemley's Avatar
1988 29' Excella
Lorena , Texas
I had one of the old cracked drain pans. After trying many things, JB Weld for plastic worked. Not the gray JB weld but the clear for plastic.
But I agree with others. Check condensate drains first. I that doesn’t get it pull the grill and look around to see where the water is dripping out of the pan or condensate lines.
Good luck!
lemley is offline   Reply With Quote
Forward Bedroom or Aft Bedroom kswelsh Community Polls 49 09-27-2020 04:57 PM
Rear bedroom vs Front Bedroom Zybane Our Community 45 07-19-2019 03:50 PM
Front Bedroom vs Back Bedroom. DaytonaDan Airstream Lifestyle 40 01-08-2019 02:15 PM
Front bedroom or back bedroom question? BRF1253 Member Introductions 17 04-01-2017 08:48 AM
