04-27-2018, 06:57 PM
#2241
2018 28' Flying Cloud
Clayton
, Georgia
Originally Posted by SteveTam9310
Our travel buddy Sue made this beautiful table for her airstream.
Is that wormy maple? It looks very nice, but can it still be lowered and used as a bed without splitting lenghtwise?
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
04-27-2018, 07:16 PM
#2242
GLCMRANGER - Sue
2016 25' International
Littlestown
, Pennsylvania
It's ambrosia maple. I reinforced it by steel bars underneath and it's doweled together. No, it's permanent......
04-27-2018, 08:19 PM
#2243
2016 20' Flying Cloud
Lewisville
, North Carolina
20-footers
Can it be made in away for those of us that need the extra bed?
Steve and Tam
04-28-2018, 01:36 AM
#2244
Sag Harbor
, New York
To clarify -- is the photo in a recent post from the front of your 25' Airstream? [per your ID to the left] And not in a 20' AS?
Noted in photo, through window: vehicle and top of propane tank cover.
By "permanent" do you mean that it cannot be lowered to make a bed?
Peter
04-28-2018, 01:39 AM
#2245
Sag Harbor
, New York
To clarify -- that photo is in the front of Sue's 25' I am guessing? Through the window note vehicle and top of propane tank cover.
Peter
04-28-2018, 05:49 AM
#2246
GLCMRANGER - Sue
Littlestown
, Pennsylvania
Good guess. It's possible to make it so it lowers into a bed. You can't see the new pedestal leg in the picture, but, it works just light the 26U. The pedestal just needs to be centered. I elected to make it "permanent" so I could make the table width narrower and a little longer. Since I'm a solo traveler (most of the time), I decided to go this route.
Addressing the "strength" -- I built it so a 500 pound person can sleep on it (ha, ha).
04-28-2018, 06:23 AM
#2247
Clayton
, Georgia
Ambrosia Maple or Wormy Maple - they're the same, 'though "Ambrosia" sounds nicer for a dining table
http://www.lewislp.com/wormy-maple-or-ambrosia-maple/
My version has some wormy maple, as well as cherry, walnut, and curly maple.
In mine the boards run sideways for bed strength, with battens under the table to make it strong lengthwise too. Mine's in a FC 28
I love how the custom tables transform the look of the interior!
Erik & Carol
Clayton, Georgia
04-28-2018, 06:26 AM
#2248
Lewisville
, North Carolina
Very very nice! Thanks for the clarification.
Steve and Tam
04-29-2018, 02:02 PM
#2249
2017 20' Flying Cloud
Ojai
Dexter lift completed
Thought I'd post my results after installing 3" lift kit for others that might be interested. We have a 2017 20' FC. Installation was straight forward with some difficulties removing old nuts and rerouting the gas line but nothing too crazy. I would still recommend hiring someone competent to do the job and make sure all nuts are torqued on properly. I have now driven about 1000 miles and don't notice any difference in towing capability. I DO notice that I am not scraping on my driveway or in gas station aprons during my travels. This was a big improvement in this regard. I had the experience (unwanted but educational) of pulling it through 50-60 MPH cross and head winds returning from Joshua Tree recently and I'm happy to report that the little Bambi did great. Let me know if anyone has questions.
Ric
04-29-2018, 02:24 PM
#2250
GLCMRANGER - Sue
Littlestown
, Pennsylvania
Nice table....... now if I had enough nerve, I'd try ambrosia maple wood slab...... but couldn't lift it to install it...... and increase in tongue weight.
04-30-2018, 08:33 PM
#2251
Lewisville
, North Carolina
Attachment 309655
Wow that is awesome!
Steve and Tam
05-01-2018, 06:43 AM
#2252
Sag Harbor
, New York
That last photo is also from a larger AS, a 28', and the earlier photo was from a 25' .
FWIW -- IMO our FC20 would feel too "busy" inside with a wood-grained table top in such a small space. We like the uniform semi-off-white color scheme of the upholstery fabric, Formica counters and table, and louvered shades, which are all reflected nicely in the aluminum-skinned interior.
The net effect is to make the small-ish FC20 feel much bigger inside, in our opinion. A dark table wood just not work . . .
YMMV!
Cheers,
Peter
05-01-2018, 06:59 AM
#2253
2016 23' International
Centennial
Good morning all.....I am posting an update on the water heater issue. The RV repair place called yesterday and said they had to do some adjustments and replace the inline fuse. They said they have left it running since last thursday and that it is running fine. Atwood now has backed out of covering it under the warranty because it was an adjustment. I reminded the repair facility that I had adjusted the tube several times and replaced several of the inline fuses. It's going to cost $236 for the repair. I will pick it up today and see what happens when I am camping this weekend. This darned water heater has been so frustrating. Cross your fingers.....I don't know what else to do. Have been dealing with this ever since buying the Airstream new in 2016.
Steve "Centennial Man"
05-01-2018, 07:01 AM
#2254
Sag Harbor
, New York
Thanks for the update, Steve, are you still covered under the AS warranty from the purchase? I would submit everything to AS and ask for reimbursement.
Speaking personally from the Northeast, it is time to get on the road again!
Peter
05-01-2018, 12:56 PM
#2255
2019 23' International
La Habra
Yes Steve, Peter is right. If this has been a problem and has not been resolved while under warranty you have a real case.
Also, the repair shop may have left it on but they did not use it like you would while camping. IOW, taking showers washing dishes etc. you want the system to cycle off and on multiple times. GL with it
2019 GMC Sierra Denali
2019 23CB International
05-01-2018, 07:57 PM
#2256
Washington
, Missouri
Steve, put you notes together. Do not pass go but. Dial 1-800 jacosoncetner. It has always been an issue with me when the dealer throws up their hands and says it's a component mfr's issue.
Take no prisoners and demand solution to your satisfaction. This is a JC warranty responsibility. I don't pass over lightly on the level of dealer support...OEM or otherwise. Personally..i see my dealer as AS.
Just like HUD and PJ's (participating judisdictions) there is no difference in policy or liability.
Good luck!
B
05-02-2018, 06:08 AM
#2257
Centennial
I am so glad you guys chimed in! I will contact Jackson Center, probably in writing, so that the trail of documentation continues. I am leaving tomorrow for a 5 day trip in the Airstream and will give the water heater a good workout then as well. I will report back.
05-02-2018, 06:28 AM
#2258
1964 26' Overlander
Warner Robins
, Georgia
Ambrosia [emoji1360][emoji307] I built kitchen cabinets with this beautiful wood. Awesome [emoji2]
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
05-02-2018, 09:07 AM
#2259
Sag Harbor
, New York
Originally Posted by centennialman
I will contact Jackson Center, probably in writing . . .
I assume you mean via email? Depending on your computer backup system, and redundancy, you might want to print out the emails, and/or write them a letter sent certified return receipt.
When our tow vehicle got rear-ended a couple of years ago, it proved very helpful that I could provide old correspondence to verify certain aspects of the insurance claim.
Have a great trip! [photo documentation required . . . ]
Happy trails,
Peter
05-03-2018, 07:16 AM
#2260
Centennial
Thanks Peter....I am going to write the letter and send it via snail mail...certified is a good idea as well. First, I will make a phone call and see where that goes. It's pouring rain, in buckets, here this morning. I am camping about 5 miles down the road from the house. Will wait to leave until this afternoon and hope the rain has let up some. I am going to keep the water heater turned on for the entire weekend and give it a good workout.
