10-27-2015, 05:16 PM
#341
Sag Harbor
, New York
Thanks Bob for the comments on music in this thread. Happy to move on to a new thread if anyone wishes . . . Thanks also for the suggestions on further Chet Atkins tunes. I don't think that 1987 PBS special is available on their store, at least on a quick look.
An update on the pump and winterization --
Our forecast through Thanksgiving does not predict any serious cold weather, so I "summer-ized" the pipes today, and plan to go to the local county campground to spend a night or two, and to dump my black water tank. I am not set up to do this at my rental cottage, although I can drain the grey water into the garden especially as it is mostly water at this point.
We are thinking of taking the trailer south to at least Virginia during Thanksgiving week. After that, who knows what!
The new pump dampener feet seem to have made a big difference in the noise, although I still need to put the large drawer back under the oven to make a final assessment. I never made contact with the HVAC contractor who I know will be able to supply the quietest feet for this. For now I just wanted it all back together.
Glad I did the initial winterization, pump dampener foot pads, and recent summerization, as I feel much more comfortable heading South, now more familiar with the coach's innards.
"Just Can't Wait To Get On The Road Again . . . "
10-27-2015, 06:14 PM
#342
2017 25' Flying Cloud
Western MA
, Massachusetts
Originally Posted by FCloud9
Mazoolah,
Miss your contributions....hoping as the originator of this "20 Footer Thread" you jump back on board!
Hi! Mazoolah and I have been so busy traveling with the trailer we haven't had a moment to jump onto the forum. And when we are home, we are either at work or falling asleep before nine!
We had a great summer and fall with our 20'fc. We were able to take it out almost every other weekend. But now it's getting close to the time to put it away for the season. Once it's tucked away in storage - I'm sure you will more postings!
10-27-2015, 06:22 PM
#343
2023 27' Globetrotter
w.springfield
, Massachusetts
Mazoolah,
Well Thanks ! I'm still lurking around , mostly just using the trailer as much as possible this summer . Starting to think about storage ,hoping to get a trip in somewhere before thanksgiving . We have a garage rental lined up for the winter but curious anybody using a portable carport/garage ?
Every flying cloud has a silver lining !
10-27-2015, 08:19 PM
#344
2019 25' International
Traverse City
, Michigan
I'm totally in with letting the thread wander around - with the focal point being our 20s.
"Don't let perfect be the enemy of better."
10-27-2015, 08:33 PM
#345
Traverse City
, Michigan
We're heading to the Carolinas the second week in November for two weeks and joining the Hunting Island Hiatus rally on 14th and 15th. We're staying outside Asheville NC a few days before the rally and at Edisto Beach a few days after. Anybody going to be in that area then?
We store in a heated garage so I've not winterized yet and plan to do that after we return. I just drain the FW tank and WH tank use the compressor to blow out the lines. This year I'm adding RV anti-freeze to the traps. We haven't traveled with the AS in cold weather so I've been reading threads about that and I think we'll be fine driving down without winterizing completely. Thoughts?
10-27-2015, 08:51 PM
#346
Sag Harbor
, New York
Do you have tank heaters? My coach happened to have them, and they are good insurance in marginal weather I guess. No experience with them as my 1985 25' AS was more basic. At least you know your trailer well, so could do a basic winterization quickly as needed. I have been following a few winterization threads which I will look for and post.
I posted some links in a few threads about The Appalachians and Asheville weather, including these monthly overviews which are helpful for planning IMO --
Virginia Beach:
Virginia Beach November Weather 2015 - AccuWeather Forecast for VA 23451
Asheville:
Asheville November Weather 2015 - AccuWeather Forecast for NC 28801
Beaufort SC:
http://www.accuweather.com/en/us/bea...onyr=11/1/2015
Note the graphs at the bottom, which are very handy to check each day if any dodgy cold weather threatens.
Have fun on your trip. I will post our progress after Thanksgiving in case we are in the same area. Have you considered starting your own thread for the trip?
10-27-2015, 09:04 PM
#347
Sag Harbor
, New York
10-27-2015, 09:14 PM
#348
2012 25' Flying Cloud
Battle Lake
We mounted the water pressure accumulator under the sink in our 25 (we also owned a 20). I don't recall there is a specific orientation, just that it must be installed on a cold water line, and anywhere on a cold water line. It comes from the factory preloaded to 30 psi and we found that is a good setting, however there is a schrader valve on the end to add more or less air.
Doug and Cheryl
10-28-2015, 04:43 AM
#349
Sag Harbor
, New York
Nice easy accessible location in your 25,' doug, and thanks for the photo. Those are the standard SS braided risers I believe? I guess gravity would do an OK job of draining the accumulator if you removed the two risers and let them also drain on a towel, after doing all the other gravity and compressed air work for winterization. Still curious what the mfg. recommends.
As you may recall, in our FC20 units the space under the large drawer under the oven is not so user friendly! I will post a photo when this Air Forums site sorts out its photo attachment issues.
TCwheels may not have to winterize his new accumulator perfectly, as he just mentioned that his coach spends the winter in a heated garage. Nice!
10-28-2015, 07:40 AM
#350
2016 30' Classic
Hinckley
, Ohio
Hello, I use to own a 2011 20'
On the water pump noise, a computer mouse pad under the pump will quite it down a lot. The pump does not need to be screwed down tight. Just enough to keep it from walking around during travels and use. The actuator tank is also not needed or recommended. There is an adjustment screw on the front of the pump. It's on the pressure switch. They can come loose during travels. All you need to do is tweak the screw one way or the other. Higher pressure equal shorter cycles.
Regards,
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
10-28-2015, 08:05 AM
#351
Sag Harbor
, New York
Thanks Bigventure I saw your post on the other thread, and am looking forward to checking this out soon. Many thanks for the heads up!
Not sure if you read my recent post about making up new pump footpads using felt and mouse pad washers, plus loose hold down screws, but it seems to have made a big difference.
Thanks again,
Peter
10-28-2015, 09:47 AM
#352
Washington
, Missouri
Being a newbie I haven't had the chance to explore and ID much less comprehend all of the systems as yet. I contacted JCtr and requested a plumbing plan with all the individual details. AS is no different than anyone else building something of significant volume, and I there must be a good set plans somewhere. They responded the following day with a pdf'd set of plans and details...19 pages worth! It certainly helped accelerate my learning curve as I'm getting ready for my first winterization this weekend. Pretty comprehensive. They should have it posted on their website. They also sent two pdf's of winterization guides (Schu's News and another updated version with pictures, I also believe from Dave Schumann).
10-29-2015, 04:22 AM
#353
Sag Harbor
, New York
Thanks.
By the way, do you know if Hagerty Insurance in TC insures classic Airstreams? Jay is looking for coverage apparently:
http://www.airforums.com/forums/f351...ml#post1703410
Perhaps you could chime in on this thread if you know? I met one of the owners back in the 90's but have not insured with them. Thanks.
Jay's main thread is about maneuvering his new (old) AS is here:
http://www.airforums.com/forums/f464...-s-142909.html
Thanks.
10-29-2015, 05:05 AM
#354
Traverse City
, Michigan
Originally Posted by OTRA15
That's a great question. Coincidently, I was over there last week and could have inquired...I'll check and then connect with Jay.
10-29-2015, 05:07 AM
#355
Sag Harbor
, New York
Here is the original photo of my pump and filter which I had difficulty posting. Thank you to the Support team and moderators for clearing up the problem yesterday!
The 1x4 valance/kick is the blonde wood at the bottom.
Here is a so-so shot of the new footpads/dampeners, with the OEM rubber feet visible above the felt furniture glides, with 2 layers of mouse pad material on the floor. [you can double click on the photo to bring up an enlargement]
Note that the screw heads are somewhat above the pump's cast metal feet and washers, to minimize vibration being sent down into the floor through the screw shafts. The screws are very tight in their pilot holes, so it is unlikely IMO they could vibrate up just from road action. Also, the intake and discharge hoses are clamped to the floor, so the pump is actually pretty well locked (loosely) in place.
The extra wiring was added as an extension cord, because one of the crimp connectors had pulled out when I was juggling the pump around last week. The new length of wire will permit moving the pump 6-8" freely if I need to do more down here.
I will put the large drawer back and check out the pressure adjustment mentioned recently, when I get around to it! A test run yesterday seemed like a big improvement with reduced noise levels.
10-29-2015, 08:18 AM
#356
2023 16' Basecamp
Chgo. N.W. Burb's
Fresh Drain Relocated.
Mounted brass ball valve next to other drains. Removed some rivets in panel cover of tank .Bend back enough to gain access to connector on tank. Put hose/clamp on this and ran thru hole ,where plastic valve was. Run hose to panel where other drains are.Mount valve & connect hose. Push back panel and re-rivet .
Now drain is easy to access.No need to get under trailer. (Orig post did not get on this thread,got lost ?)
10-29-2015, 08:50 AM
#357
Sag Harbor
, New York
Thanks. You posted in the Two Water Drains? thread I think. Useful in both spots! Any chance of a photo of the knu location?
10-29-2015, 01:02 PM
#358
2023 16' Basecamp
Chgo. N.W. Burb's
Will try to get tomorrow.
10-30-2015, 07:25 AM
#359
Sag Harbor
, New York
Originally Posted by Bigventure
[snip]
[snip]
On our 2014 FC20, the pressure switch is on the right end of the pump as you see it under the oven, looking toward the curb side of the coach (see recent photo in Post 355 here).
This shot shows my left hand reaching into the pump space, over the 1x4 kick/valance, with the red ballpoint pen pointing to the allen-head adjustment screw (I believe -- see YouTube video link below). This shot is thus looking toward the coach's front:
In my opinion this switch should be adjusted ONLY if the pump is cycling on and off during a shower, or something like this. It has nothing to do with reducing the actual noise level of the pump (think decibels). Again, the YouTube video covers this.
Note that he has the pump "upside down" compared to my photo, the red wires will orient you.
10-30-2015, 07:58 AM
#360
2016 30' Classic
Hinckley
, Ohio
I agree with OTRA15. Thanks for those photos and the follow up to my suggestions.
Some where going to install a accumulator tank, when I made the pressure switch suggestion.
Some of your pumps are variable speed units. My 2011 had one. They sound very different than the others. They start off slow and build up speed. Some times they will just lub dub along.
