Old 09-27-2017, 04:04 PM   #1
Anywhere , Alabama
Winter water
Hi folks. Question about water connections in winter. We've been full time for 4 years. Until we got our 2017 Classic we lived in 5th wheels. They all had heated compartments for water connections. We use an electric heated water hose also. So what do folks do for freeze protection inside the small compartment in the classics where water connection and black tank flush are?
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 09-27-2017, 04:16 PM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
What worked for me on my 17 Classic was making my own heated hose and leaving 3' of heat strip on the male end to wrap around those parts.
If you look inside, you will see a side panel inside with 3 screws? Take off, and carefully lay in your favorite insulation all around the regulator, inlet water tube, etc. Then stuff gray closed cell foam in the forward bottom edge of that box just behind the back wheel, to keep road water splash out of the box. That's the only place mine ever froze up and not completely, but down to a slow drip overnight in the teens.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 10-17-2017, 10:44 AM   #3
Anywhere , Alabama
Thanks, where exactly did you put the closed cell foam. I have a pretty good sized gap that the door partially covers when closed. My arm is a little short to reach it.
Matt & Pam Padgett
Anywhere, USA
Old 10-17-2017, 11:42 AM   #4
Obviously-NOT
Kalispell , Montana
The gap I filled with closed cell foam is directly behind the rear tire. When you remove the inner panel and crane your head just right or stick your smarty-pants phone in there for a selfie, you'll see the city water regulator, the black tank flush line, and on mine, a big gap of daylight leading to the rear tire.
Pink insulation laid in for the tubing and regulator, closed cell to minimize tire splash to keep the pink dry. Lay in well, but don't stuff.
Cheers,
Old 10-18-2017, 07:20 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
My approach has always been to use the tank and fill it when the weather is warm.
The 2010 classic I have has a hole in the bottom of the little compartment where the water (and black tank flush) connection is, so that it is possible to fully close the compartment door while the hose is connected. This would provide a degree of protection from freezing. Water conducts heat well, and with a heated hose there is as a practical matter some protection beyond the end of the hose.
Old 11-07-2017, 06:46 AM   #6
Anywhere , Alabama
Hey James, have you checked the insulation you put behind the panel after driving in the rain. I did what you said, even used a piece of gorilla tape on the gap outside. After a trip in heavy rain, I looked behind the panel and most of the pink insulation as wet and nasty. Road water getting in the nooks and crannies.
Matt & Pam Padgett
Anywhere, USA
Old 11-07-2017, 06:50 AM   #7
Obviously-NOT
Kalispell , Montana
Going back to check? Hmm, should I guess. Thx.
Old 11-07-2017, 06:52 AM   #8
Obviously-NOT
Kalispell , Montana
Funny, same problem we had on nuke subs
Old 11-07-2017, 07:01 AM   #9
dznf0g's Avatar
Oswego , Illinois
I am not sure if newer classics are the same but:
1) There is a brass one-way check valve in the water line (under the bath sink and on the floor in front of the water heater).
2) This valve is there to isolate the outside bib and the city water hookup from the rest of the plumbing and pump/tank system.
3) there is a bypass valve around this brass check valve which enables you to use tank water at the bib in the warm months, when the valve is open.
Here is the winter prep:
1) while thoroughly blowing out the entire system in winter prep, be sure you open the bib and completely exhaust all water. The air fitting is at the city water inlet.
2) with the air flowing, close the bypass valve at the brass check valve.
3) release the air pressure. The brass check valve will close and prevent any on board fresh water from entering the lines upstream (now downstream while using tank water and pump) from the check valve (and the now closed bypass valve).
4) the outside compartment lines, bib and city water pressure regulator and lines are now devoid of any water and filled only with air.
5) leave hose bib open to prevent any drips from freezing and damaging it. Also, an open bib will allow for you to ensure there is no slow leak from the bypass and brass check valves while using pump and tank water.
-Rich-
Old 11-07-2017, 08:45 AM   #10
1994 25' Excella
Atlanta , Georgia
While winter camping in my ‘94 Excella Classic I always connect to 110v so I can run the furnace. I simply place a trouble light with a 60 watt incandescent bulb in the water connection compartment. This has worked well to zero degrees. I
Mike Steele is offline   Reply With Quote
Old 11-09-2017, 11:05 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
A bit off topic, but vaguely related .....
If you happen to be *in* a Classic in cold weather, the windows get a bit damp. The water runs down the window and puddles in the track at the bottom of the window. You can build up a pretty good pool fairly quickly. I have empirical data on this . Popping open the window and bailing it out with a rag is about the only practical way to take care of the issue. If the pool just sits and the trailer cools down .... you have a block of ice pushing the window around. That's probably not a good thing
uncle_bob is online now   Reply With Quote
Old 11-14-2017, 08:45 AM   #12
Obviously-NOT
Kalispell , Montana
Uncle bob, you are a lifelong learner, still my hero.
When we cut the 1/4 inch silver bubble insulation for the windows, leaving no air gaps between it and the windows was key to avoid the convection dehumidification and slow flooding.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Water heater use in the winter PSchw Sprinter and B-van Forum 15 11-09-2013 08:57 AM
draining water lines for winter glarue All Argosy Trailers 4 09-11-2013 03:47 PM
Water filters, winter system draining and etc. malconium Water Heaters, Filters & Pumps 1 12-31-2009 08:18 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
