I have had several of these come loose over the past 2 years. I ended up using a larger screw. The standard size is marginal as it has to get through the felt first, then into the wood. To get decent access, I ended up removing the entire panel from the wall. If you have to do this it isn't that difficult. In addition to the small screws that are above and below, the units screw together on both the left and right sides.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
