Old 10-05-2020, 11:59 AM   #1
2020 33' Classic
Saint Johns , Florida
What Size is the Low Pressure Quick Connect
Does anyone know what size the quick connect is on the low pressure propane port? I tried a few google searches and forum searches but could not find it... thanks in advance.
TheCols is offline   Reply With Quote
Old 10-05-2020, 12:07 PM   #2
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
From my experience, I assume its the same size but I could be wrong. I bought several hoses and all of them fit without knowing what size.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 10-05-2020, 12:11 PM   #3
2020 33' Classic
There are different sizes. You must have got lucky.
Old 10-05-2020, 12:22 PM   #4
Halford1's Avatar
whooo got the Luck of Irish with me that day.
Old 10-05-2020, 01:31 PM   #5
steverino's Avatar
2018 30' Classic
Ivins , Utah
Images: 8
There are two different standards for the disconnect - one for air, one for propane. They differ in the shape of the connector. Type A or type B, I do not recall which. They usually come with 1/4 male pipe thread (NPT) to connect to your hose.
steverino is offline   Reply With Quote
Old 10-06-2020, 09:32 AM   #6
1976 31' Excella 500
Chappell Hill , Texas
1/4”
tbashin is offline   Reply With Quote
Old 10-06-2020, 09:56 AM   #7
Graham , North Carolina
Low Pressure Port Size
Have just finished buying fittings and hoses to connect my newly converted to propane generator. My 14 Sport has a 1/4 fitting. Was told by local propane company 1/4 is fairly standard for RV use but 3\8 are more common in other usages.
Also learned that gas and air quick connect fittings are NOT the same.
LDDuffy is offline   Reply With Quote
Old 10-06-2020, 10:10 AM   #8
2014 25' FB Flying Cloud
Albany , Oregon
We tried camping world and several other places but finally found the right one at a propane dealer. I got a couple that fit but wouldn’t allow propane to flow.
FlyingCloud7 is offline   Reply With Quote
Old 10-06-2020, 10:39 AM   #9
2018 16' Sport
Tacoma , Washington
I recently had a propane extension hose made at a local shop that makes hydraulic hoses. The Mr Heater part number F276181 is the quick-disconnect fittings that work in my AS.
They had 3 different 1/4" propane connectors to choose from. The only difference I could see was the length of the snout. The first male connector I tried would fit into the AS Low Pressure Port, but no gas came out. I returned it and got these which work as expected.
2011 Ford Explorer Limited with factory tow package
2011 Harley-Davidson Ultra Limited
Runamuk13 is offline   Reply With Quote
Old 10-06-2020, 04:17 PM   #10
2000 28' Excella
Godfrey , Illinois
Quick Connect fittings
https://www.mbsturgis.com
A good source for all things LP related, especially quick connects.
Relaytest is offline   Reply With Quote
Old 10-06-2020, 04:49 PM   #11
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
^^ what Relaytest said.
You don’t say what year and model trailer you have. On my 2014 25 FB the fitting on the trailer itself is an MB Sturgis Model 250: https://mbsturgis.com/products/model...ct-x-1-4-fnpt/
GammaDog is offline   Reply With Quote
Old 10-06-2020, 05:18 PM   #12
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
This one worked perfect for our grill. Can get hose in whatever length you want. I believe there is a recommendation for length that someone will likely chime in on.
SHINESTAR 24FT RV Quick Connect Propane Hose, Easy Release RV Connection Hose for Fire Pit, Camp Chef Stove, Pit Boss Burner Grill, 3/8 Female Flare x 1/4 Full Flow Male Plug
https://www.amazon.com/dp/B07Q2Q5LPN..._yPpFFb5S6VSPS
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 10-07-2020, 04:53 AM   #13
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Mine is 1/4". If you will be using it for a grill, you will need to remove the regulator as there is already one on your AS. With 2, you will not get enough propane to cook with. As LDDUFFY mentions, get propane (tapered at the end) fittings because they all not the same.
Mikebrady62 is offline   Reply With Quote
Exterior LP Port Quick Connect Size 25FB is 1/4" AirstreamCSH LP Gas, Piping, Tanks & Regulators 0 05-01-2017 02:45 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
LP pressure at convenience quick connect 1jacobo Sprinter and B-van Forum 6 09-11-2016 03:53 PM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 04:20 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 06:26 PM
