Old 09-29-2017, 07:36 AM   #1
Anywhere , Alabama
Water regulators
Howdy from Santa Fe. Do any/all of you rely solely on the onboard water pressure regulator or do you use one at the pedestal to protect your hose.
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 09-29-2017, 07:51 AM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
My Camp Host gig at a UT State Park had variable pressure up to 100+ psi, so they strongly encouraged using one at the pedestal. Mine has a simple gage, but can go more or less complex.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-29-2017, 08:28 AM   #3
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
I've done it both ways, currently depend on the onboard unit.
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
Old 09-29-2017, 09:34 AM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I always put one on at the faucet.
CRH is offline   Reply With Quote
Old 09-30-2017, 11:43 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Anything over 120 PSI is getting into the "yikes!!!" category. Your beat up old hose may or may not be happy with a 150 psi water source. There's also not a lot of reason for them to be running that sort of pressure.
If the campground is running 40 PSI water, you want every ounce of pressure they are supplying. Each reducer you have inline will drop the pressure a bit, even if it is below the regulation point.
It very much turns into a "that depends" sort of thing. So far for us, the internal regulator has done just fine.
Old 09-30-2017, 11:52 AM   #6
Mollysdad's Avatar
Cheap insurance.
Old 09-30-2017, 01:23 PM   #7
PKI
PKI's Avatar
Walnut Creek , California
Using an adjustable at the faucet. It's not to protect the hose, but rather to insure the delivery pressure to the coach is controlled. Will install an on-board adjustable regulator and accumulator tank in the future, but the outboard works for now. Pat
Old 09-30-2017, 01:41 PM   #8
Half a Rivet Short
Hi
I believe that the Classics all come with onboard pressure regulators these days.
Old 10-09-2017, 07:40 AM   #9
2018 30' Classic
New York , New York
We have just used onboard. We took the outside one off the spigot in order to increase the pressure which was around 40 psi, but have kept it to check before hooking it up.
ajwbarnard is offline   Reply With Quote
Old 10-09-2017, 09:22 AM   #10
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
If you have a location with very low pressure (Or erratic pressure) you can fill your fresh water tank and eliminate the problem.
WayneG is offline   Reply With Quote
Water Pressure Regulators - DO THEY WORK? perryg114 Fresh Water Systems 45 01-23-2014 06:06 AM
System Regulators Maxson LP Gas, Piping, Tanks & Regulators 3 10-13-2009 06:07 PM
Are LP regulators adjustable? gparker LP Gas, Piping, Tanks & Regulators 9 01-22-2007 01:51 PM
Propane connects and regulators. raebaker06 Repairing/Replacing Floor &/or Frame 1 01-05-2005 11:40 AM
