Old 09-03-2020, 05:36 AM   #1
2019 30' Classic
Norcross , Georgia
Water leak in 30 RBQ bedroom
After driving all day in heavy rain, I found some water in the bedroom coming out of the USB and bed-switch outlets on the rear-TV side of the bedroom.
A quick look outside didn't identify any obvious seal gaps but there is a running light almost opposite where the outlets are but again no obvious gaps.
Curious why the water would come out of the outlets rather than run down the inner wall do the floor--maybe a lateral rib at the outlet level is catching the water?
Any ideas would be much appreciated!
PaulR-GA is offline   Reply With Quote
Old 09-03-2020, 05:53 AM   #2
Is it January yet?
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
Water has a knack for being mysterious. In the early days of my 2019 Flying Cloud, I had a total of 4 water leaks over the first 3 heavy rain storms we encountered.
Only one of the leaks (Fantastic Fan seal) was obvious; the other 3 were very tricky. Where we observed the water was nowhere near the source of the leaks. If the service center didn't pressurize the trailer and spray soapy water on the entire outside to find the bubbles, I'm not sure we would have ever tracked down the origination points. I tell this long story to make a relevant point: One leak was coming through an electrical outlet, but we found the water was getting in behind the seal on the front window rock guard plexiglass. The entry point and the exit point are quite far from each other.
Once identified, it was an easy fix. Good luck.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 09-04-2020, 10:55 AM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Water always finds the path of least resistance.
Start high and work low. The faster you can seal it up the better. Be on the lookout for missing, damaged, or light sealer areas.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
2018 28 FC RBQ Early Mods kb7our 2016 - Current Flying Cloud 29 10-18-2019 01:49 AM
New 2019 Int's Signature 28 RBQ Jkreis 2016 - Current International 2 08-12-2019 08:13 PM
New 2018 26 RBQ Night owls Towing, Tow Vehicles & Hitches 2 01-15-2019 12:39 PM
2017 28 RBQ - Sitting up in bed??? philly_air 2016 - Current Flying Cloud 10 04-13-2018 05:35 PM
30' RBQ: Space at the back of the wardrobe motozen Airstream Lifestyle 3 02-09-2018 09:56 AM
