Old 11-12-2017, 08:44 AM   #1
Anywhere , Alabama
Water Intrusion
Been chasing water intrusion from driving in rain. Everyone should take a look inside the wheel well behind rear wheel. There is a bracket that is supposed to sit flush with the black skirting. They even have a piece of gasketing material to fill in gap. Well on my off door side, the gap is over 1/2" wide and gasketing is doing nothing. So, pretty sure that's where rain is getting in. The fit up is really poor around the water cabinet and inside the wheel wells.
Well, nothing gorilla tape won't fix.
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 11-12-2017, 09:49 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
It's worth noting that it does not take much of a rock to knock some of this stuff out of whack. For those who tow their Classics through .... ummm..... errr ..... bean fields it's worth checking the wheel wells while spraying all the mud off the rest of the trailer.
Old 11-12-2017, 02:37 PM   #3
Anywhere , Alabama
See pictures. Fit up is poor and no attempt to fill in. Click image for larger version
ID:	298912Click image for larger version
Matt & Pam Padgett
Anywhere, USA
Old 11-12-2017, 03:59 PM   #4
Half a Rivet Short
Originally Posted by lukeysh714 View Post
See pictures. Fit up is poor and no attempt to fill in. Attachment 298912Attachment 298913
Hi
Maybe it's just late .... I'm having a hard time figuring out the orientation of those pictures ....
Old 11-12-2017, 04:03 PM   #5
Cave Creek , Arizona
I didnít have a water issue but the mice found this to be an easy entrance. There is a rubber gasket that doesnít close the gap. After getting rid of the mice I filled the gaps with sikaflex
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 11-12-2017, 04:08 PM   #6
dznf0g's Avatar
Oswego , Illinois
Mine had sealer in that area....not well sealed though. I added for a complete seal. Has lasted 7 years.
-Rich-
Old 11-12-2017, 04:45 PM   #7
Anywhere , Alabama
Hi
Directly behind rear wheel looking back.
Matt & Pam Padgett
Anywhere, USA
Old 11-14-2017, 09:55 PM   #8
2016 30' Classic
Lorton , Virginia
I spray foamed all those openings. Not only could they let highway moisture in, they also are a big source of drafts.
Zybane is offline   Reply With Quote
Old 11-15-2017, 01:13 AM   #9
Reads a lot
Titusville , Florida
Thanks for the heads up.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 11-15-2017, 04:42 AM   #10
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Yep, went to storage and found the curb side open like this but the road side solid as can be. I suspect in travels it either worked it's way loose or I hit something to knock the curb side out. So, as it' supposed to be in the high 40's this week I repair both sides with some Silaflex 221 an then I know it won't move.
Bud
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
Old 11-16-2017, 06:19 AM   #11
Anywhere , Alabama
Bud, take a close look at the gaps around the water cabinet also. Found lots of nooks and crannies that will let in road water or even cold air. I used closed cell foam and gorilla tape, so I could remove it if necessary. The fresh water feed line and the black flush line are in that area, so if there is a leak, I can pull back a piece of tape to let it drain out.
Matt & Pam Padgett
Anywhere, USA
Old 11-16-2017, 11:16 AM   #12
I also recommend spray foaming the cavities adjacent to the slide rails on your steps to keep out the elements and rodents. Find a can with a long enough straw to ensure when the foam expands it does not interfere with the steps or the spring latching mechanism
Pete B55
2017 Classic
2017 F-250
Old 11-17-2017, 06:56 AM   #13
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Great thread, I found a thumb sized hole forward, port of center line, in the floor deck where cables penetrate up into the cabin. Great for routing the trickle charger cord, but as the cable bundle had shifted down, all the factory sealant used was a couple inches below the hole.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 11-17-2017, 11:35 AM   #14
paiceman's Avatar
James are you going to use spray foam or some other kind of sealant?
Bud
Bud
Old 11-17-2017, 05:35 PM   #15
Obviously-NOT
Kalispell , Montana
Well, I've stuck 0000 steel wool in a few little pukas like that. Didn't want to close it up permanently yet.
Old 11-18-2017, 04:45 AM   #16
paiceman's Avatar
Thanks. But the steel wool will rust in there.
I found some pipe insulation at Home Depot the other day, which I think I can put in the hole, basically fill it up and yet be able to remove if need be. Might cover the insulation with a large piece of rubberized tape with adhesive on it I found at a plumbing supply house.
Bud
Bud
Old 11-18-2017, 08:43 AM   #17
Half a Rivet Short
Hi
Steel wool (or most metals) against the aluminum skin probably isn't a real good idea. I *assume* (as in I haven't checked with a magnet ... yet...) the lower flashing is aluminum. A bit of spray paint in the area before you stuff the steel wool in likely "solves" the problem. (I don't trust anodize ....).
Old 11-20-2017, 07:56 AM   #18
Anywhere , Alabama
Hi
Black flashing is not aluminum. Not magnetic.
Matt & Pam Padgett
Anywhere, USA
Old 11-21-2017, 03:52 AM   #19
Obviously-NOT
Kalispell , Montana
Sorry, the steel wool I used inside in the big floor holes last fall after the first two stowaways were caught. I used some closed cell foam pipe wrap chunk stuffed in to block the hole for the cables from the bottom.
Old 11-21-2017, 08:08 AM   #20
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
I just filled all the gaps /holes I could find underneath with Stuf-fit copper mesh and Great Stuff pest block spray foam sealant. Hoping it will discourage rodents and reduce bugs that get any big ideas.
Water intrusion at rear bumper - What years affected? RFP Repairing/Replacing Floor &/or Frame 44 06-28-2018 02:02 PM
Intrusion Alarm? Winetripper Electronics & Connectivity 7 05-24-2012 11:47 PM
pardon the intrusion Y2k_Knight Our Community 2 04-06-2009 09:26 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
