Old 05-06-2021, 08:14 AM   #1
2018 30' Classic
Carlisle , Pennsylvania
Voyager camera died, wire inside
My Voyager camera died and while removing the camera the wires came unattached and went down the hole. How to I retrieve them? There seems to be a "larger than the hole" tube or conduit in-between the walls that I can't get. Any and all help will be much appreciated. I did order a replacement camera. Thanks again for all the help. Mike
mike2 is offline   Reply With Quote
Old 05-06-2021, 08:34 AM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
They are generally wired into the centre clearance light. If you can not reach the wire that came loose and dropped, I think you can simply pull out the wire from the clearance light and wire the new camera in.
thewarden is offline   Reply With Quote
Old 05-06-2021, 08:41 AM   #3
1965 17' Caravel
Canton , OH
If you think the wire fell less than 2 feet, there are "grabber" tools available that are about 1/4" diameter and 24" long with four little bent flat wire "claws" that retract or open as you push/release a plunger on the other end. I have used one many times to retrieve bolts etc. that I have dropped in tight spaces. Maybe one of those would work. Most auto parts stores have them.
John S. WBCCI 14118
1965 17' Caravel
2020 Ford Ranger Lariat SuperCrew w factory tow
jwschnettl is offline   Reply With Quote
Old 05-06-2021, 01:55 PM   #4
2018 30' Classic
Thank you for the suggestion.
Old 05-06-2021, 01:56 PM   #5
2018 30' Classic
Thanks, it sounds like something I need in my toolbox anyway.
Old 05-06-2021, 01:57 PM   #6
2018 30' Classic
Thank you it sounds like I should have one in my toolbox anyway.
Old 05-07-2021, 01:39 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
It is time for a skinny wire clothes hanger, a pair of needle nose pliers, and pair of dikes. Straighten out the hanger. On one end bens a "U" shaped hook. On the other bend a 90 degree handle in the same direction as the "U." I have fished many lost from view items that way.
guskmg
Old 05-07-2021, 03:49 PM   #8
2021 30' Globetrotter
East Northport , New York
No too long ago I picked up an inspection camera from harbor freight. It comes in handy for things like this.
https://www.harborfreight.com/27-in-...era-64623.html
It just bailed me out when replacing the factory Zamp combiner box with an AM Solar box. The 8 gauge wires were hung up and wouldn't pull through to reach the new bus bars. I dropped a couple of the ceiling lights inside the trailer and with the camera was able to identify that there was plenty of slack and a simple plastic stick on clip was holding the wire back. I taped a wire hook to the end of the camera and was able to guide it right to the wire and pull it free. Maybe overkill for your situation but an option if needed.
James
Biker is offline   Reply With Quote
Old 05-08-2021, 05:52 AM   #9
2018 30' Classic
guskmg
Thanks, love the idea, as soon, or if it ever stops raining in Pa, I’ll give it a try.
Old 05-08-2021, 05:54 AM   #10
2018 30' Classic
Thanks, I have get one and start looking, always something. Thanks again.
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 06:54 PM
Voyager rear view camera image upside down jamieb1086 Audio, Video & TV 11 05-18-2018 05:32 PM
Voyager WiSight Camera works 50% of the time. Ted S. Electronics & Connectivity 14 08-20-2015 09:54 PM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 06:32 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
