Old 02-23-2021, 10:15 AM   #1
TimT's Avatar
2019 30' Classic
Clovis , California
Unusual issue with ALDE
Hi Everyone,
I been having issues with my Alde system for a while, it doesn't work as it is supposed too......I turn it on and nothing happens, but on my last camping trip I noticed the system came on when I turned on the extra hot water for the shower...mmmm.....it ran fine for about thirty minutes or so until the extra hot water system shut down on its own....
Is it possible that the system is hooked to the wrong circuits on the Alde box under the dinning seat?.....has anyone else experienced this type of problem and does anyone have a possible solution...
Tim
TimT is offline   Reply With Quote
Old 02-23-2021, 12:22 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Originally Posted by TimT View Post
Hi Everyone,
Tim
What system do you have and what multiplex (firefly or czone)?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 02-23-2021, 03:29 PM   #3
TimT's Avatar
2019 30' Classic
Clovis , California
I have Czone system...2019 classic
Old 02-23-2021, 10:20 PM   #4
2018 30' Classic
Check to ensure the alde flow box is checked in the options menu.
Are you saying that you are not certain the hot water heater is working or the radiant heat? Or both?
BigSxyWhtGuy
Old 02-24-2021, 04:49 AM   #5
2018 33' Classic
Ancaster , Ontario
Look at the voltage on your ALDE panel. I had a similar problem and the dealer has ordered a new control board for our ALDE. The house voltage was good but the ALDE voltage was ready low.
Happy-rver is offline   Reply With Quote
Old 02-24-2021, 06:22 AM   #6
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
I have a 2021 Classic 33. That is exactly how mine works - I originally thought mine was broken too. I researched and found this in my owners manual:
Shower Boost Mode
Before taking a shower it is recommended the “boost” function be activated 10 minutes prior. This can be done by pressing the button for shower boost from the Alde control panels “menu” screen. Turning ON the boost function will temporarily suspend heat to the trailer and raise the water temperature. After 30 minutes the system automatically returns to normal operation. Boost mode can be canceled and the system returned to normal operation before the 30 minute run time by pressing the button.
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Old 02-24-2021, 09:38 AM   #7
TimT's Avatar
2019 30' Classic
Clovis , California
I may not have stated the problem well enough....my current Alde system does not come on by itself at all....been a issue since last year, and I had it worked on several times by the dealer and when I take my next trip camping somewhere it won't work again. it has been a very frustrating problem to remedy so far...
The last trip I made a few days ago I turned on the extra hot water button to heat up extra hot water for showers, and all of a sudden the trailer heat came on instead of extra hot water for the shower....the system does regularly provide the normal hot water for the sinks, and bathroom faucets.
My question to the group is ..... is it possible the system is not wired correctly or is something misconnected.....I shouldn't be getting trailer heat when I turn on the extra hot water button, but in this case I am. I am happy the trailer heat comes on, but it only lasts for about thirty minutes or so until the system shuts down automatically.
Old 02-24-2021, 01:30 PM   #8
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Everyone,
Tim
Hi TimT,*
Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 03-01-2021, 08:23 AM   #9
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Tim,
The simple answer is yes. However, there is a lot more information required to arrive at that conclusion. How comfortable are you with poking around in your Alde hardware? I had no boost hot water in my system for the first 18 months I owned her. She spent months (yes you read that correctly) in several different Airstream dealers who tried to diagnose the problem. I finally decided I needed to find the problem myself or I would never take a shower in my trailer. I dove in. I found the problem fairly easily and with some help from the forum fixed it. No costs except my time. We (because others will help and there is a lot of knowledge on this forum) can walk you through a proper diagnosis and perhaps find a solution without a trip to the dealer.
First question: Are you full timing?
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
Froglips is offline   Reply With Quote
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 56 06-08-2020 01:55 PM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
MasterCard ad with A/S Unusual 74Tradewind Our Community 3 04-07-2003 06:57 PM
unusual AS pics "jrnymnJay" NewStreamer Our Community 7 12-01-2002 06:34 AM
