Old 12-11-2018, 11:23 AM   #1
2018 30' Classic
Callao , Virginia
Turning on the gas
Just wondering if it is normal to have to purge the gas lines (by lighting the stove first) prior to getting then frig or the Alde to work on gas? We had three gas leaks when we first bought the unit and I fixed them, just wondering if anyone else has had this experience? I'm thinking we have another leak it's only been a few weeks since we used the gas and I had to purge it.
Airhead2018 is offline   Reply With Quote
Old 12-11-2018, 12:08 PM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
It's pretty typical when the propane has been shut off at the tanks for a few weeks to need to purge the lines a bit when you first turn the gas back on.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
Old 12-11-2018, 12:46 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I agree, a few weeks of shut off tanks will require a line purge.
Richard
Old 12-11-2018, 04:04 PM   #4
1986 31' Sovereign
Miami , Florida
Once everything is working, shut of both tank valves and then check regularly for an "empty propane" indication (on mine it's a red line". Unless it happens really quickly, you are okay.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 12-12-2018, 05:28 AM   #5
2018 30' Classic
Callao , Virginia
Not answers I was expecting. I will check all the lines again just to make sure and if nothing is found then OK. Thanks to all for input!!
Atwood gas hot water heater not turning off murphy Water Heaters, Filters & Pumps 2 06-27-2014 02:04 PM
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 08:27 PM
POR15 turning green pinkflamingoes Clearcoat, Exterior Paint & Trim 2 01-20-2005 04:09 AM
Turning radius rmcdon8848 General Motorhome Topics 7 10-14-2004 05:45 AM
turning axles smallfry Axles 7 01-08-2003 10:39 AM
