Old 10-05-2017, 12:39 PM   #1
Silver is the new black
madogkenno's Avatar
2018 30' Classic
NAPA , California
Trailker Brakes
I just purchased my 2018 Classic 30.
My brake system is a Prodigy 2. It worked well on my 2006 Komfort tow-able.
This unit reads 6.1 - 6.2 - 6.3.
In crawling traffic the trailer started to lock up. I cleared the settings by moving front lever from right to left. It still locked up.
I reset the dialing wheel to all three settings 6.1 - 6.2 - 6.3. No help.
I finally got through the traffic snarl. The next day, on a clear road I reset the brakes to 6.1, and it seems to have cleared up.
I stopped by a trailer hitch shop. The guy tells me my trailer has to learn the controller on it's own and it should to go.
Am I missing something here? Am I safe to go back out on the road, or should I be looking to replace the P2? If so, replace to what, a P3? or is there a better brand?
KT
madogkenno is offline   Reply With Quote
Old 10-05-2017, 01:35 PM   #2
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Not much help here, our trailer controller is built into our F350 and in two Airstreams now so far no issues. There is an Airstream repair facility in Sacramento, he used to be in the NAPA area - Vinnie's Airstreams, you might try calling him. Even living in PA he has helped me out.
Bud
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
Old 10-05-2017, 02:56 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
The guy at the hitch shop is either a poor communicator or poorly informed. The trailer doesn't "learn" anything about the brake controller.
Now, I found the P3 to be finicky in long traffic engagements. I generally ran it at boost level 2 on the highway but in traffic or around town if I didn't turn boost off entirely, it would start to get "grabby" with the brakes after a few applications in quick succession. I don't know if this is different behavior from the magnets or brakes when they heat up, or some odd behavior of the time+accelerometer guesstimations the Prodigy does or what. And, I changed truck and trailer at the same time so I never towed our original trailer with the new truck with the built-in brake controller.
Still, I experienced something very much like you, with the next model of the Prodigy, on a 2-axle trailer with drum brakes. If there's a boost on the P2 you can turn on and off easily, see if that improves things.
— David
Old 10-05-2017, 03:25 PM   #4
Vintage Kin
Fort Worth , Texas
P2 or 3 is a basic controller, in a manner of speaking. One shouldn't use a lesser unit.
The OP might look at threads on the TUSON DirecLink. Much more sophisticated.
Several users who post frequently.
How these things work is worth understanding.
Can the drum brakes be changed to disc brakes? MOS Brakes & Brake Controllers 56 10-29-2020 04:27 AM
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
