01-02-2021, 01:47 PM
2023 27' Globetrotter
Pleasant Garden
Trailer bounce when parked
We have just parked our 2019 30' Classic at a rv resort for the next year. The site is great and leveling the trailer was a breeze. We have our stabilizers down and x braces between the tires. We still have some bounce and shake when we walk or move around inside the trailer. can we put some other type of stabilizers under the trailer that will help with this?
01-02-2021, 03:15 PM
2018 30' Classic
Thousand Oaks
It won’t ever be perfect IMO. Ours is the same, you can still feel when someone is walking around though. We do have RV Snap Pads on our stabilizers — jury is still out if they truest help but my wife swears they do.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
01-02-2021, 04:08 PM
2022 25' Flying Cloud
NCR
we use the JT Strong arm stabilizers
a few years ago our campsite neighbor's 5th wheel had them.
in our AS, we use 6 of them, 2 upfront 4 in the rear.
the unit is solid as a rock now.
01-02-2021, 04:18 PM
Sag Harbor
, New York
01-02-2021, 04:46 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
, *** Big Sky Country ***Western Montana
Or, several screw jacks from a used tool store placed periodically at the frame rails.
Do not over tension them to distort the frame.
01-02-2021, 05:12 PM
1993 34' Excella
Estancia
Wont hurt anything. Get used to it.
01-02-2021, 05:50 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
If this trailer is rocken...
01-02-2021, 06:24 PM
2019 27' Globetrotter
McHenry
There it is...
And there it is, the first thing that came to mind when I saw the post title. Only took 7 posts...
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
01-02-2021, 06:48 PM
2014 25' Flying Cloud
Cuddebackville
, New York
When I set the stabilizers I go back the next day and snug them up again. It makes a difference.
2019 Ford Expedition Platinum
01-02-2021, 06:52 PM
2021 33FB Classic
City
, West Virginia
I find it helps to use higher leveling blocks before putting them down. I, too, re-tighten every few days and that seems to help.
01-03-2021, 05:33 AM
Sag Harbor
, New York
A great suggestion Chas and Cindy -- in effect this makes the steel arm of the leveler into a diagonally angled brace, rather than an almost-vertical column [which is a very unstable support for unwanted lateral sway movement].
jeff, I had the same immediate reaction -- "If this van is rockin' . . . " -- bumper stickers all over the place, back in the 60's and 70's!
01-03-2021, 05:39 AM
Sag Harbor
, New York
. . . some other . . . that will help with this?
"Walk softly and . . . "
01-03-2021, 05:50 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Some of the bounce and movement is a result of the torsion axles and shock absorber suspension. As you are going to be on the site for a year you could put jacks at the lift points and take the weight off of the wheels/tires. This will help with the bounce and also prevent flat spots from developing on the tires.
Ray B.
01-03-2021, 08:25 AM
2004 30' Classic Slideout
Fenton
Even with the stabilizers down you will find that unless you are on a paved surface, the ground will give way over time, especially if you have rain. The key to setting the stabilizers is to stop extending them once you detect a rise in the trailer. Too much rise and you will see problems with the entry door opening and closing. No rise whatsoever means the jacks are providing little support.
Sounds like you have used all the devices that I would recommend. But overall understand that you can't expect that trailer to give you the same support as something built on a foundation or with multiple supports scattered throughout the frame. It's noticeable if you are sitting and someone is walking around in the trailer. I have a friend who is heavy walker and quite honestly some people are heavy walkers and some aren't.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
01-03-2021, 12:13 PM
1988 32' Excella
Robbinsville
, New Jersey
This is good advise but, for more then a few days you should use jack stands and have wood under them, unless on concrete.
01-03-2021, 01:41 PM
2017 30' Classic
The Panhandle
, Idaho
RV Bouncy
The only RV I have ever been in that did not bounce, and this numbers well over 100 rigs, was a high end Class A with leveling jacks. These jacks were designed to lift the MH so the tires were completely off the ground; the jacks were taking all the weight. My friend that owned this MH said he could still feel bounce when there were a lot of people inside, but I couldn't detect it.
Our Classic 30 also bounces a bit when we walk around.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
01-03-2021, 01:43 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
We have that with a shorter 23D, but only with the Mrs. I tend to walk more softly than her, and my stride is almost perfectly straight forward. Her stride is maybe 5-10 degrees to the outside, which causes a little bounce for us.
01-04-2021, 03:09 PM
Newcastle
, Oklahoma
Have to agree with OTRA15. This is the second blog I have seen today on bounce. We chock the wheels and drop the 4-corner stabilizers and call it good. I also always felt the little movement that exists was just part of it. Sort of reminds me of the old homestead from years ago with the conventional floors.
Enjoy
MC
Better to remain silent and be thought a fool than to speak and to remove all doubt.
01-10-2021, 01:18 PM
Brook Park
X-Chocks.
01-10-2021, 01:28 PM
2021 33FB Classic
City
, West Virginia
I am buying this:
Camco Save-A-Step Brace, Stabilizes RV Steps and Helps Prevent RV Movement. Protects RV Steps from Sag and Wear (7-5/8"-14") (43691) https://www.amazon.com/dp/B0024E6ZW2...ing=UTF8&psc=1
Thanks to Luke Grisott! In our 33’, with using the “X’s” - our only movement was when some was going up or down the steps - this product fixes that! Thanks Luke.
