Old 01-02-2021, 01:47 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Trailer bounce when parked
We have just parked our 2019 30' Classic at a rv resort for the next year. The site is great and leveling the trailer was a breeze. We have our stabilizers down and x braces between the tires. We still have some bounce and shake when we walk or move around inside the trailer. can we put some other type of stabilizers under the trailer that will help with this?
jlandreth is offline   Reply With Quote
Old 01-02-2021, 03:15 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
It won’t ever be perfect IMO. Ours is the same, you can still feel when someone is walking around though. We do have RV Snap Pads on our stabilizers — jury is still out if they truest help but my wife swears they do.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 01-02-2021, 04:08 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we use the JT Strong arm stabilizers
a few years ago our campsite neighbor's 5th wheel had them.
in our AS, we use 6 of them, 2 upfront 4 in the rear.
the unit is solid as a rock now.
Name:	JT strong arm stabilizer-1.jpg
ID:	386077   Click image for larger version
Name:	JT strong arm stabilizer-2.jpg
Name:	JT strong arm stabilizer-3.jpg
waninae39 is online now   Reply With Quote
Old 01-02-2021, 04:18 PM   #4
Long Island , New York
Trailer bounce?
That is part of the romance of having an Airstream!
Let the music lift you up . . .
Old 01-02-2021, 04:46 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Or, several screw jacks from a used tool store placed periodically at the frame rails.
Do not over tension them to distort the frame.
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 01-02-2021, 05:12 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Wont hurt anything. Get used to it.
Old 01-02-2021, 05:50 PM   #7
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
If this trailer is rocken...
sheriff1 is offline   Reply With Quote
Old 01-02-2021, 06:24 PM   #8
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
There it is...
And there it is, the first thing that came to mind when I saw the post title. Only took 7 posts...
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-02-2021, 06:48 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
When I set the stabilizers I go back the next day and snug them up again. It makes a difference.
2019 Ford Expedition Platinum
Old 01-02-2021, 06:52 PM   #10
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
I find it helps to use higher leveling blocks before putting them down. I, too, re-tighten every few days and that seems to help.
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Old 01-03-2021, 05:33 AM   #11
A great suggestion Chas and Cindy -- in effect this makes the steel arm of the leveler into a diagonally angled brace, rather than an almost-vertical column [which is a very unstable support for unwanted lateral sway movement].
jeff, I had the same immediate reaction -- "If this van is rockin' . . . " -- bumper stickers all over the place, back in the 60's and 70's!
Old 01-03-2021, 05:39 AM   #12
. . . some other . . . that will help with this?
"Walk softly and . . . "
Old 01-03-2021, 05:50 AM   #13
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Some of the bounce and movement is a result of the torsion axles and shock absorber suspension. As you are going to be on the site for a year you could put jacks at the lift points and take the weight off of the wheels/tires. This will help with the bounce and also prevent flat spots from developing on the tires.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 01-03-2021, 08:25 AM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Even with the stabilizers down you will find that unless you are on a paved surface, the ground will give way over time, especially if you have rain. The key to setting the stabilizers is to stop extending them once you detect a rise in the trailer. Too much rise and you will see problems with the entry door opening and closing. No rise whatsoever means the jacks are providing little support.
Sounds like you have used all the devices that I would recommend. But overall understand that you can't expect that trailer to give you the same support as something built on a foundation or with multiple supports scattered throughout the frame. It's noticeable if you are sitting and someone is walking around in the trailer. I have a friend who is heavy walker and quite honestly some people are heavy walkers and some aren't.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 01-03-2021, 12:13 PM   #15
1988 32' Excella
Robbinsville , New Jersey
This is good advise but, for more then a few days you should use jack stands and have wood under them, unless on concrete.
Old 01-03-2021, 01:41 PM   #16
The Panhandle , Idaho
RV Bouncy
The only RV I have ever been in that did not bounce, and this numbers well over 100 rigs, was a high end Class A with leveling jacks. These jacks were designed to lift the MH so the tires were completely off the ground; the jacks were taking all the weight. My friend that owned this MH said he could still feel bounce when there were a lot of people inside, but I couldn't detect it.
Our Classic 30 also bounces a bit when we walk around.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
Hoagie is offline   Reply With Quote
Old 01-03-2021, 01:43 PM   #17
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
We have that with a shorter 23D, but only with the Mrs. I tend to walk more softly than her, and my stride is almost perfectly straight forward. Her stride is maybe 5-10 degrees to the outside, which causes a little bounce for us.
banderabob is offline   Reply With Quote
Old 01-04-2021, 03:09 PM   #18
MickeyC's Avatar
Newcastle , Oklahoma
Have to agree with OTRA15. This is the second blog I have seen today on bounce. We chock the wheels and drop the 4-corner stabilizers and call it good. I also always felt the little movement that exists was just part of it. Sort of reminds me of the old homestead from years ago with the conventional floors.
Enjoy
MC
Better to remain silent and be thought a fool than to speak and to remove all doubt.
MickeyC is offline   Reply With Quote
Old 01-10-2021, 01:18 PM   #19
Brook Park , Ohio
X-Chocks.
chdeatley is offline   Reply With Quote
Old 01-10-2021, 01:28 PM   #20
2021 33FB Classic
Cumming , Georgia
I am buying this:
Camco Save-A-Step Brace, Stabilizes RV Steps and Helps Prevent RV Movement. Protects RV Steps from Sag and Wear (7-5/8"-14") (43691) https://www.amazon.com/dp/B0024E6ZW2...ing=UTF8&psc=1
Thanks to Luke Grisott! In our 33’, with using the “X’s” - our only movement was when some was going up or down the steps - this product fixes that! Thanks Luke.
2021 Classic 33 FB
WBCCI# 8026
Controlling Bounce Whizzo Jacks, Stabilizers, Lifting and Leveling 12 03-17-2013 10:24 PM
Bounce Wiggle Rock Wobble Seesaw P&J Jacks, Stabilizers, Lifting and Leveling 11 02-14-2010 11:34 AM
A new kind of "Bounce" plan COArgosy78 Off Topic Forum 47 01-10-2004 01:04 PM
How much floor bounce/give is normal? JHarper Repairing/Replacing Floor &/or Frame 4 01-07-2004 07:13 PM
Floor Bounce? Jabba Repairing/Replacing Floor &/or Frame 4 05-14-2003 04:12 PM
