Old 04-26-2018, 03:52 PM   #1
Paul Kukstis
paul.kukstis's Avatar
2018 30' Classic
Scituate , Massachusetts
Sub woofer not working
Have a 18 Classic 30... with music playing nothing is coming out of the sub woofer - no sound of vibration - using the Polk ultramarine app it shows a control for it but it is not active -
Not connected? Defective?
Anybody else have this issue?
paul.kukstis is offline   Reply With Quote
Old 04-26-2018, 04:08 PM   #2
Cave Creek , Arizona
While doing an unrelated project in my 17 Classic I noticed the sub-woofer audio line in the trailer harness was abandoned and a separate audio line was run from the Polk, under the dinette, through the Alde register to the subwoofer under the couch. It looks like the harness wire had been damaged after installation and before it left the factory someone caught it and did a quick work around. Check your wires - both audio and DC to the subwoofer. Make sure the audio signals are getting there and the local fuse has not blown. Its easy to get to the subwoofer. Pull off the lower kick-panel at couch center, remove two large nuts on front edge underside of couch center section, and pull the entire center section (front and back) straight up.
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 04-26-2018, 05:04 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
And make sure it's turned on at the subwoofer. Mine has a switch there and I turn it off when boondocking to avoid the battery drain.
2019 Ford Expedition Platinum
Old 05-31-2018, 10:07 PM   #4
Bougeois's Avatar
Lakeland , Tennessee
RCA booster makes it work. RCA cables are to long.
Bougeois is offline   Reply With Quote
Old 06-01-2018, 04:32 AM   #5
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
When I removed and replaced our couch with recliners I noticed that the RCA cables were hardly connected and easily unplugged from their respective male/female plugs. So, when I put the whole mess back together I wrapped some tape around them. Might check the white and red RCA cables under the couch.
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) - 68-72
Old 06-01-2018, 05:31 AM   #6
2018 30' Classic
Callao , Virginia
I agree with all who posted. Wiring is unfortunately like a can of worms so roll up your sleeves and get in there.
Airhead2018 is offline   Reply With Quote
Old 06-01-2018, 05:42 AM   #7
Sag Harbor , New York
Is there a reset button on the back of the subwoofer maybe?
Good advice here all around . . .
Old 06-01-2018, 06:17 AM   #8
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I don't think there is a reset button, but there might be a fuse, or even a volume pot on the subwoofer. Many of use have simply unplugged the sub in the past, and left it that way, for a variety of reasons.
Old 06-01-2018, 07:02 AM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Are you connected to shore power? Sub does not work on battery power.
Old 06-01-2018, 02:43 PM   #10
It runs on 12v in the classic
Pete B55
2017 Classic
2017 F-250
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
How can you know a sub floor is not rotten? davcarv Buyer Guidelines 4 04-24-2012 06:08 AM
Sub-woofer needs delay circuit M&M CAPECOD Audio, Video & TV 9 05-22-2005 01:52 PM
