Old 11-07-2020, 07:19 AM   #1
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
Storage Facility RV Wash
I store my 2019 AS & TV in a single bay heated storage facility that has its own RV wash. I do get 10 free RV washes a year, but I have refrained from using the wash facility. I have resorted to getting my AS washed and wabernized annually at my dealer. Posted are the two chemicals used at the wash facility.While these chemicals clean the TV spotless, I am concerend about the finish on my AS. Would you allow you AS to have these chemicals sprayed on it? All opinions are appreciated.
ID:	382708   Click image for larger version
trikdacy is offline   Reply With Quote
Old 11-07-2020, 08:28 AM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Well if the clear coat on your TV hasn't dissolved and washed away, what's the concern?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 11-07-2020, 08:45 AM   #3
2018 25' International
Slidell , Louisiana
The presoak, cuts, softens and dissolves bugs and road grime quickly. Not intended to stay on very long. Easier on waxes and sealers than dishwashing detergent and useful if the trailer has bugs and grime.
The detergent is good for paint and has several enhancers that also are designed not to dissolve sealers and waxes so badly.
Neither of these would be good for non clear coated aluminums so they would want to be rinsed off, dried and then the uncoated aluminum should be resealed or waxed. I have removed the clear coat from a few of the bolt on components like the door handle, rear lights, etc. due to Filiform corrosion.
Brian
Old 11-07-2020, 09:06 AM   #4
Mollysdad's Avatar
I'd have reservations on using anything marked "corrosive".
Sulfuric acid?
Old 11-07-2020, 10:23 AM   #5
Slidell , Louisiana
All undiluted, ph balanced detergents are corrosive...
One uses sulfuric acid to ph balance the other sodium hydroxide. The ingredients list is not the same as the reacted final product.
Brian
Old 11-07-2020, 11:30 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I only use a quality car wash soap or wash wax on all our wheeled vehicles and one floating one.
Just tried this as an application method, works very well on the Burb and DW's MB. Apply to half, wash down with microfiber mitt.👍
Looking forward to Spring to try it on "Cloudsplitter"
Obrigado, hora de descansar.
Tahawus
Old 11-07-2020, 01:56 PM   #7
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
I wish my storage facility had a wash bay.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB - Fly Fish Inn
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 11-07-2020, 02:35 PM   #8
Jeff7176's Avatar
Silver Spring , MD
I use the same. Works great.
Jeff7176 is offline   Reply With Quote
Old 11-07-2020, 03:51 PM   #9
I've used it twice so far, one container with a 1/3oz soap mixture did the Burb and the same ratio did the MB with half a container left.
Plus the foam lasts on the surface long enough to wash.
MacGyver gives it a AAA+👍
Tahawus
Old 11-10-2020, 10:00 AM   #10
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
Conflicting Answers
I emailed both the HCS detergent manufacturer and Airstream. I have attached replies from both contacts. I will not be using the RV wash at my facility.
Name:	From AIRSTREAM.jpg
ID:	382926   Click image for larger version
Name:	From AIRSTREAM1.jpg
Old 11-10-2020, 03:43 PM   #11
Slidell , Louisiana
trikdacy,
Airstream replied it would be safe for clear coated surfaces just as I affirmed. The manufacturer also replied that it is not completely safe on (uncoated) Aluminum and Aluminum Alloys as I affirmed. Ye of little faith.....
Brian
Acid wash or no acid wash? alan.aliciac 1959-69 Tradewind 10 09-04-2015 10:12 PM
Hand wash VS power "car wash" TommyL Cleaning, Stripping & Polishing 2 04-12-2010 02:50 PM
STORAGE FACILITY REQUEST Near Mill Valley California TinCrumpet Global 'streaming 2 12-11-2009 12:54 PM
Storage facility in South Denver needed. IrishRover2 Off Topic Forum 3 02-26-2008 05:34 PM
Any Storage Facility Close to NYC ?????? Silvercamper On The Road... 5 10-21-2005 08:52 PM
