Old 11-11-2018, 05:10 AM   #1
Steaming Hot Toilet?
I apologize upfront for the bathroom humor this topic may draw, but I am seriously beginning to think I have a bathroom water supply piping defect in my 2018 Classic 33FB. I have two primary symptoms that lead me to believe my shower and toilet are plumbed solely from the Alde hot water tank.
Symptom 1: No matter how I adjust the temperature valve on the Alde (note: I have read the forum posts and direction on loosening the screw to allow for adjustment) I cannot adjust the water temperature at the shower mixing valve. In other words, whatever temperature it is set for at the Alde temperature valve is the only temperature I get regardless of the position of the shower mixing valve. This results in unbearable nearly scalding temperatures if I engage shower boost.
Symptom 2: After a beer and bbq dinner party, I engaged shower boost for hot washing dishes. Several guests were using the macerator toilet. I heard laughter in the bathroom and a guest then called me in and demonstrated a flush that resulted in a steamy event similar to a mild geyser at Yellow Stone. There was clearly steaming hot water feeding the toilet. My guess is that we had not seen the hot geyser phenomenon prior to that time because the toilet had not been used multiple times in a short period so as to draw hot water all the way to the toilet. The hot water has not affected the function of the toilet, but I do not risk burns by flushing when seated.
Another note.....the bathroom sink, outdoor shower and kitchen sink faucets function normally providing hot to cold water as desired.
I can live with the hot geyser toilet (it is a good source of humorous conversation during parties), but the inability to adjust the temperature of water in the shower is inconvenient and literally a pain.
Your advice is appreciated.
jrkott is offline   Reply With Quote
Old 11-11-2018, 05:26 AM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
What color is the pex that feeds the toilet?
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 11-11-2018, 05:26 AM   #3
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Your plumbing is clearly a hot mess. Time for a warranty visit to your dealer!
Old 11-11-2018, 05:35 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Jc'qc
Haste makes Waste...hot.😂👎
Obrigado, é hora de descansar.
Tahawus
Old 11-11-2018, 07:40 AM   #5
Lakes Region , New Hampshire
Be careful of that bidet thread going on.
"Anyone, who actually fought for it, would know that the freedom we fought for, was so no one could tell us what we have to do." -me
RandyNH is offline   Reply With Quote
Old 11-11-2018, 08:54 AM   #6
I will check the pipe color later today.
Old 11-11-2018, 09:13 AM   #7
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
I would check the position of you shut off valves under your dinette. If it didn't do it from the start (hot toilet water), it sounds like you have a valve turned to the wrong position. The manual isn't much help (at least my 2018 manual) as the diagram isn't up to date for the 33s. I would check position of winterization bypass valve. Fingers crossed.
JDG is online now   Reply With Quote
Old 11-14-2018, 08:25 PM   #8
I could not figure out how to see the color of the supply line to the toilet without getting into carpentry. I also looked at my paper manuals and could not find any information for the proper Alde valve settings for the 33 classic. Without removing the bench, I cannot trace the location of lines on the Alde. I experimented with several different variations of valve settings and the only two results I got for the toilet and shower was all hot water or no water. This is very frustrating because I take a shower that is unadjustable almost scalding hot then goes cold. I hope the dealer can resolve this. The lack of manual information provided is totally unacceptable for a $120,000 investment!
Old 11-14-2018, 08:55 PM   #9
2002 19' Bambi
Lafayette , California
I suggest not waiting to get to the dealer, but to call Airstream directly.
Tim
Tim A. is offline   Reply With Quote
Old 11-15-2018, 04:12 PM   #10
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi jrkott,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
How hot is hot? tn2 General Motorhome Topics 10 05-21-2007 04:01 PM
Steaming To Chama, New Mexico Rally Kevbo10 Other Rallies & Events 3 05-29-2006 02:19 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
