Old 11-05-2020, 05:18 AM   #1
2018 30' Classic
Lake Charles , SW Louisiana
Splash Guards
Any fellow members here devised a means of fabricating and installing splash guards on/in the rear wheel wells of their Classic?, i.e. to prevent road debris from striking the tank valves and small 12v light fixture or compartment doors?
I've made a set of rubber form fitting guards for my '18 Classic using 1/4" thick neoprene type fabric bonded rubber but yet to install them. Plan is to rivet them in place with a small piece of thin stainless plate at the lower edges of the wheel wells just inside behind the rear axle wheels and use sealant behind them to preempt water penetration. (i.e. just need to triple check, that doing so will not penetrate any wiring or plumbing lines behind the wheel wells - but suspect the 1/4" mounting holes I need to drill (4-per side) will be low enough that they should not interfere with anything). To do so, I plan is to pull the wardrobe cabinet base to inspect the backside of the curbside w-well, and pull the forward dining booth bottom seat cushion to inspect the area near the floor on the backside/rear of the road side w-well before I commit.
Curious what others may have done.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Replacing your plexi glass Rock Guards / Stone Guards PeterH-350LE Rock Guards, Segment & Window Protectors 46 05-25-2021 06:31 PM
Splash Guard/Mud Flap Bob & LaVon Land Yacht/Legacy Motorhomes 0 05-17-2010 01:24 PM
Splash of glitz and a skosh of fun wheel interested General Interior Topics 42 03-23-2010 05:08 AM
2002 396XL Splash Guard Kpoo General Interior Topics 0 12-30-2009 02:57 PM
back splash walls in aluminum; CCD owners please help SmokelessJoe Cabinets, Counter Tops & Furnishings 5 05-09-2007 10:43 AM
